filippo
by filippo » Fri Sep 21, 2007 3:07 pm
Indigo don't render explosion whit particle flow...why?
indigo don't see that the mesh is broken..
filippo
sorry for my poor language
by suvakas » Fri Sep 21, 2007 3:43 pm
Yes, particle flow is not supported. Actually i've never tested it before.
If you can upload the max scene, then maybe i can take a look at it at some point.
filippo
by filippo » Fri Sep 21, 2007 11:36 pm
ok..I post the scene immediatly....in the zip file you can se the animation whit vray..
- test exp.zip
- file max
- (33.46 KiB) Downloaded 248 times
- esposione 1.rar
- animation file
- (1.26 MiB) Downloaded 254 times
by suvakas » Sat Sep 22, 2007 6:17 am
I checked the scene and it seems that it can't be done. Can't convert Particle Flow to a mesh object. So nope, no support for PFlow.
Moses
by Moses » Sat Sep 22, 2007 3:22 pm
To make particle flow a mesh go to the geometry button and on the list rollout where it says standard primitives go to compound objects and select mesher.
by suvakas » Sat Sep 22, 2007 7:37 pm
Thanks for the hint Moses!
Seems to work fine. And i think i also found a way how to do the same thing via maxscript automatically. That should add a better overall particle support as well. We'll see how it turns out.
by suvakas » Sun Sep 23, 2007 6:44 am
Ok. The scene Filippo posted exports fine now. But since i don't know how to use Particle Flow, then I have no idea if it works for other scenes too. Probably not
Here's the rendered animation
LINK (divx6).
Rendering time about 3 hours on quad.
psor
by psor » Sun Sep 23, 2007 6:52 am
So cool ...
Thanx Moses for the advice and thanx to you suvakas for
taking the time to add it to the exporter ... hehe! ;o))
take care
psor
"The sleeper must awaken"
by suvakas » Sun Sep 23, 2007 7:07 am
Don't thank me yet. I have no idea if it works in other situations.
Anyone knows if there are any free PFlow scenes in the net? Something i could use for testing?
