SomeQuestionsFromNewUSER
Continuing to learn This wonderfull program...
Some questions:
1. What settings for pool water (with green-blue reflectance)
2. how often did you use sampling > 1 in big Images (>3000x*)
I am concerned be course nowedays i have 1Gb RAM and in my observations - results are identical (or pretty much)
3. Where is the materrial Library? Few weeks ago I foundet link to it, but now i didnt
PS I choose Indigo becose Fry dont want render with low memory and I think indigo very usefull, but need some convenience like Fry. My Exmple is: Indigo+violet=one programm and how did you think ppls
Some questions:
Re: SomeQuestionsFromNewUSER
1) greenishblue reflection comes from the greenishblue pool walls - you need simple water (I dunno, how much chloride effects the water, though)vux wrote:Continuing to learn This wonderful program...
Some questions:
I am concerned because nowadays i have 1Gb RAM and in my observations - results are identical (or pretty much)
3. Where is the material Library? Few weeks ago I found link to it, but now i didnt
PS I chose Indigo because Fry doesn't want render with low memory and I think indigo is very useful, but needs some convenience like Fry. My example is: Indigo+violet=one program and how do you think ppls
IoR = 1.33
2) ??? - about the Ram: you don't need it for the full process. Ram is used for the Image size and for supersamples. (Or also for very hires textures or very detailed highpoly scenes) - if one or all of those are very high, your PC might get slow, as swapping is needed
3) Currently not in use (it exists, but you can't register, so, you also can't submit materials - you can download them, though
http://elqx.com/indmatdb/
currently, you need to use this thread:
http://www.indigorenderer.com/joomla/fo ... php?t=2009
and that Indigo + Violet was suggested several times, already
what's "big res"?
that's very variable^^
for me, big res, starts at 1000². others might say, big res = 10000²
usually, for big res, you EVER use supersample factor 1 (although even "my" big res 1000² works at at least Supersamplingfactor 3 - slow but without crash)
btw, WHEN does it crash? Does it render, already? Or at the beginning? if it starts crashing from beginning, you might want to lower "Hybrid value" or something like that... It has the wrong name, in Blendigo, but there's a Tooltip "set the amount of tris, when Hybrid mode shall be used" - actually, there should stand "BiH mode", as it doesn't at all affect Hybrid, but it builds the KDtree in a different way: WAY faster, available for WAY bigger scenes, but slower to render
The reason why Indigo and Violet are two separate apps is that bloom, for instance, has to be evaluated again after each image upload (every 30s by default), and that's sooo time consuming... Some people were waiting for bloom update for a while, and during that time Indigo isn't computing the image. It's much better to set these parameters once for all, when the image is computed, than every 30s
I make no outputs for printings so I can't really answer that, but anyway if your Indigo crashes on higher supersamples settings you have no choice but to lower them.
Oh and now I remember that only a few days ago someone told that supsamp of 1 was ok for high rez because the very same process of high rez printing is softening edges IIRC.
Users browsing this forum: No registered users and 77 guests
