Where is The North in Blender?
It is might be a stupid question but unfortunately I dont know...
uhm.... I'd *say* if you look from up to the scene, north is at the upper edge of your screen
- but it's absolutely undefined. That has to be decided for your scene - if you've a house, in example, you rotate the sun, so that it comes from the same position, related to the houses real north, even if you aligned it to be straight to the axes, instead of straight to north
mrCarnivore
Guys, read between the lines!
He doesn't want to know where north is, but how to change the colour of the sunlight...
Indigo calculates the colour of the sunlight according to the _angle_ from the ground up and not from the angle in top view. So if you set the sunlight to straight down you have bright noon light which is a little blue and if you set the angle almost even with the ground you get very red light like during sunset/sunrise.
- joegiampaoli
It has been threaded befor, read along....
http://www.indigorenderer.com/joomla/fo ... sc&start=0
Users browsing this forum: No registered users and 104 guests
