Crash Indigo 0.8 stable
Hello
I'm very new to Indigo and just followed the german basic tuturial for cindigo.
I installed the exporter 0.8.2 in cinema 4d 9.102.
I followed the instructions of the tutorial.
But if I load the exported igs- file into indigo 0.8 it crashes.
Here is the text of indigo monitor:
scene file path: 'C:\Dokumente und Einstellungen\Administrator\Desktop\Cindigo_Test_002.igs'
Using working directory path 'C:\Dokumente und Einstellungen\Administrator\Desktop'.
created world.
Loading Scene 'C:\Dokumente und Einstellungen\Administrator\Desktop\Cindigo_Test_002.igs'...
sun_theta_rad: 1.570796
sun_solid_angle: 0.000060
Sky zenith luminance (cd/m^2): 1988.199951
Sun spectral radiance (Wsr^-1m^-3) at 500nm: 1384112256.000000
Using Reinhard tone mapping with pre_scale=6.000000, post_scale=1.000000, burn=6.000000
loading external model 'C:\Dokumente und Einstellungen\Administrator\Desktop\Cindigo_Test_0020.obj'...
Found reference to material 'defaultMat'.
OBJ parse took 0.00299s
loaded model.
loading external model 'C:\Dokumente und Einstellungen\Administrator\Desktop\Cindigo_Test_0021.obj'...
OBJ parse took 0.00029s
loaded model.
loading external model 'C:\Dokumente und Einstellungen\Administrator\Desktop\Cindigo_Test_0022.obj'...
OBJ parse took 0.00175s
loaded model.
Building Mesh 'Cindigo_Test_0020'...
0 vertices (0B)
0 triangles (0B)
Couldn't find matching cached tree file, rebuilding tree...
TriTree::build()
calcing root AABB.
What have I done wrong ?
Regards
Alain
created world.
loaded model.
loaded model.
loaded model.
0 vertices (0B)
0 triangles (0B)
TriTree::build()
calcing root AABB.
Regards
Alain
jep, could an RAM issue.
The Cindigo Exporter is still in a Beta status check here for a Buglist.
You'll maybe need to hand edit your exported igs a bit...
welcome to Indigo
++edit++
best to use latest cindigo and indigo versions!
welcome to Indigo
++edit++
@fused
does not work if I use a parametric plane without an object tag.
there comes another errormessage as you can see below.
what is "bidirectional" on a plane ? and what is a "finite area mesh" in cinema ?
can anyone translate that in german ?
I converted the plane in a polygonobject with an object tag an that worked.
- Errormessage.png (3.22 KiB) Viewed 3536 times
finite is the oposit of infinite (endlich und unendlich)Alain wrote:@fused
Bi Dir is a render setting for Indigo it should speed up interior and Caustic renderings a bit (but it doesnt woork with an infinite floor!),
deactivate it if you really need an infinite floor using the indigo advanced settings in the Cindigo render tag.
btw: nice interrior!
