Blank black renders in Blendigo 09t4s
6 posts • Page 1 of 1
teamonster
Post by teamonster » Thu Aug 16, 2007 7:50 am
Hi, I installed Blendigo_v09t4s.exe. and I manually unpacked indigo 09 test 4. I double checked the path in the conf. file
I have created a basic scene with a cube and a plane. The exporter comes up with a very basic interface. I click on export and the indigo renderer window comes up, it processes the data without error and then I get a nice black blank screen.
I've tried different materials on the cube and plane and even used a sun and 'regular' lamp in Blender. No change.
Any ideas?
Post by Kram1032 » Thu Aug 16, 2007 8:33 am
Which lighting did you set?
regular lamps get ignored, sun will get exported, when you set that to "Environment and Sun" - but as a standard setting, it's on background light, with the useful value "black" which means, no light at all...
teamonster
Post by teamonster » Thu Aug 16, 2007 8:46 am
Thanks Kram1032. I found the menu for that. I've used an earlier version of an indigo exporter. I usually use the bottom window for scripts and it was off the top of the screen! Silly.
If you wanted to use emitter meshes, how would I set that up?
Post by Kram1032 » Thu Aug 16, 2007 9:07 am
1) Make your emitter
2) Make it having an "Emit" Material, in Material section of the export GUI.
Check your normals, for that ;) - Ah, and "Light" is NOT a material (except Textured Emitter), don't be irritated, by that.
teamonster
Post by teamonster » Thu Aug 16, 2007 9:31 am
Thank you Kram1032!
Post by Kram1032 » Thu Aug 16, 2007 11:01 am
No problem, really, but a hint:
look into previous threads - such questions where asked hundreds of times, already ;)
Users browsing this forum: No registered users and 107 guests
