Test exit_portal...commenti.
Questa è la mia prima immagine che posto nel forum.
Elaborata in circa 80minuti con AMD x2 5000.
- prova interno si portale ok-+.jpg (298.54 KiB) Viewed 17125 times
Giojazz,
Wow! Very nice work!
I would like point out one more minor issue though.
The way the doors in the cabinet are modeled to resemble a frame and panel construction. That means the direction of the texture of the stiles needs to be different from the rails. One needs to be vertical, the other horizontal.
Don't let those suggestions discourage you! It already needs a second look to figure out that is a computer generated image. Most people who I show my pictures and who don't know that it is computer generated don't give it a that second look and are usually quite surprised once they have been told.
If you apply those few rather simple fixes they will not be able to tell the difference.
BTW. Nice textures! Would you be willing to share where you got that nice texture on the bowl containing the fruit ?
- Kosmokrator
and the banana is slightly misshaped, I'd say...BbB wrote:The furniture's fine. I think it's more the size of the apple. Man, that's one big m*********er.
then, the named gaps and
and the other scales...the direction of the texture of the stiles needs to be different from the rails. One needs to be vertical, the other horizontal.
Besides these, the render is VERY good
Don't forget, to have the correct scale in exporters.
What do you use? Blender? Then, 1 meter = 1 Blender Unit
Vi ringrazio per i vostri complimenti, appena avrò un pò di tempo cercherò di apportare all'immagine tutti i vostri consigli, l' immagine non è stata calcolata in 80 minuti, chiedo scusa...mi sono confuso con i tempi, ma in 130 minuti.
testo tradotto in modo automatico.
Thank you for your congratulations, when I have some time I will try to make the image all your advice, the picture was not calculated in 80 Minutes, I apologise... I am confused with the times, but in 130 minutes.
translated text automatically.
Users browsing this forum: No registered users and 109 guests
