MoI test
MoI test
Post by BbB » Thu Aug 02, 2007 8:12 pm
Hi there, haven't been here for a while so I thought I'd post this little something here. It's a modelling test done using Moment of Inspiration, a wonderfully intuitive NURBS modelling software that, for now, is free (http://www.moi3d.com/). I know many of you would have heard about it, but since we don't seem to have many MoI models in the gallery, I thought I'd drop this here. To me, this is a perfect complement to Blender, as it allows manipulations that would be nearly impossible to achieve in a poly modeller, and it delivers amazingly clean .obj meshes when using a reasonably high poly count. The models were imported in Blender and rendered with Indigo 08.
SmartDen
Post by SmartDen » Thu Aug 02, 2007 8:28 pm
Beautiful, very clean render and amazing models!
CoolColJ
Post by CoolColJ » Thu Aug 02, 2007 8:31 pm
looks like eyeballs :)
Post by BbB » Thu Aug 02, 2007 8:37 pm
The more I use MoI, the more I like it. My only gripe is the high poly count you need to make NURBS objects work plausibly as poly meshes, which does slow down Blender quite a bit. I obviously need to keep experimenting a bit more to get a better compromise between realism and speed.
(also, if anyone's interested, you're well advised to split all edges in Blender after importing .obj models from MoI to avoid bizarre normals behaviour - you can still see some slight errors along the rim of the outer sphere on the second, slightly blurry, model at the back.)
SmartDen
Post by SmartDen » Thu Aug 02, 2007 8:43 pm
it would be nice you make a little tutorial. something like quick start...
CoolColJ
Post by CoolColJ » Thu Aug 02, 2007 8:47 pm
I'm gonna try it out now...
Post by BbB » Thu Aug 02, 2007 8:48 pm
I've been fumbling in the dark myself, but I can work on a little explanation about how I imported these in Blender for rendering. Bear with me for a few days.
CoolColJ
Post by CoolColJ » Thu Aug 02, 2007 8:55 pm
thanks for the heads up on the program, its very stylish looking and easy to use. sweet. Love the icons and overall look
Post by BbB » Thu Aug 02, 2007 9:00 pm
Yes, I think so too. Much easier to approach than Rhino (though the author also developed Rhino, as far as I understand). And what a relief to have Boolean operators that actually work!!!
SURFiNG
Post by SURFiNG » Thu Aug 02, 2007 9:27 pm
I love MoI , it's similiar to Rhino (developper was a Rhino coder), the only problem is that im totally SICK of this free software that when in final it will cost a lot of money...
Gibson said that it will cost 200$ when in final
Post by BbB » Thu Aug 02, 2007 9:30 pm
I don't know. 200 bucks may seem high (unless your currency is the euro :D ) but it's still much lower than most of the comparable stuff out there...
Post by OnoSendai » Fri Aug 03, 2007 12:38 am
Nice test BbB.
crsrma
Post by crsrma » Fri Aug 03, 2007 3:07 am
Did you use the N-gons export? I ask as I know Blender doesn't have true support for that, and your mesh looks nice & clean.
MoI is great to work with, hardly need a keyboard. :)
Post by BbB » Fri Aug 03, 2007 3:22 am
Yes, that's what I used. I find Blender messes up with tris. Then again, you really need to split all edges in order to get the mesh clean when smoothed.
crsrma
Post by crsrma » Fri Aug 03, 2007 3:31 am
Ahhh, yes... EdgeSplit? That cures a lot of woes.
