Macrob
by Macrob » Sun Jul 29, 2007 2:06 am
Hi! I play with a scene and sometimes I get "strange colors". When I change the distance to the object (water) it works.
- only Metropolis, no bidir
- im1185631301.png (298.5 KiB) Viewed 13597 times
- bidir; Reinhard 2/3
- im1185630673.png (1.08 KiB) Viewed 13599 times
- bidir-picture "pimped" with Violet linear, full exposure, smallest contrast.
- out.jpg (23.86 KiB) Viewed 13599 times
Macrob on Sat Aug 04, 2007 10:11 am, edited 1 time in total.
DaveC
by DaveC » Sun Jul 29, 2007 2:16 am
Is your water a specular object with transparency on, or is it glossy_transparent? I had similar problems with a specular material... i believe it is a bug the nick is currently working on
Macrob
by Macrob » Sun Jul 29, 2007 2:19 am
Specular, transparent, IOR 1.33.
OK, a bug
DaveC
by DaveC » Sun Jul 29, 2007 2:27 am
Try changing it to glossy_transparent.
tobak30
by tobak30 » Sun Jul 29, 2007 11:11 am
i too got some trouble with the material settings. i have made a simple wave wit a fluid material inside. and when i have applied the glass material in blendigo the material just turn out black. dont know what to do really. is that one part of the bug too? or is there any secret settings i have to do? I have set the material sto specular and hva had glossy transparent and just specular on it. with some different settings for the transparent thingy. like 1.33 and 3.00 and 1.55 etc. but it allways stays black.
Macrob
by Macrob » Sun Jul 29, 2007 8:59 pm
Hmm, check the normals, reduce gain, ... (?)
by OnoSendai » Sun Jul 29, 2007 9:27 pm
I think the error might be due to the glass intersecting the table.
Try moving it like 0.5mm off the table.
Macrob
by Macrob » Fri Aug 03, 2007 5:25 am
HI Ono! It does not work
I deleted the glassplate on the table and had the glass not intersecting the table. But the water intersects the glass.
Still funny black-green-yellow pictures after a short time of rendering.
by OnoSendai » Fri Aug 03, 2007 5:26 am
Can you upload the scene pls?
Macrob
by Macrob » Fri Aug 03, 2007 5:53 am
.igs or .blend?
by OnoSendai » Fri Aug 03, 2007 6:01 am
igs thx
Macrob
by Macrob » Fri Aug 03, 2007 6:15 am
I deleted some stuff (door, radiator, picture, ... ) because the igs is 25 MB.
It still renders ok(?).
Can I post the original filesize?
by OnoSendai » Fri Aug 03, 2007 6:34 am
25MB is a bit big...
Macrob
by Macrob » Fri Aug 03, 2007 6:40 am
The reduced scene still renders with no problems. ??
I try to get it smaller with funny colours.
Macrob
by Macrob » Fri Aug 03, 2007 7:10 am
Here we go
- 4.igs.zip
- This works. I deleted some stuff
- (1.71 MiB) Downloaded 216 times
- 3.igs.zip
- zipped
- (2.58 MiB) Downloaded 239 times
Macrob on Fri Aug 03, 2007 7:18 am, edited 1 time in total.
