Maxigo 0.9.3c
Maxigo 0.9.3c
Here is the first version of Maxigo for Indigo 09.
2 main features added are Exit Portals and Textured emitters.
Exit portal is defined by applying "ExitPortal" modifier to the geometry. Normals of the exit portal must always face inwards. If you get black image while using portals, then flip the normals of your portal geometry by using the "Normal" modifier.
Here's the change log:
Changes in v.0.9.3c:
* added - Exit Portal Modifier
* added - Emitter texture (Emitter material)
* added - OBJ with no material applied renders red
* added - "Super Sample Factor" (Advanced Setup rollout)
* added - "Max Num of Consec Rejections" increased to 99999 (Advanced Setup rollout)
* fixed - opening image with custom name in Max Virtual Frame Buffer
* changed - diffuse and phong materials are compatible with Indigo 09
Have fun!
Suvakas
Have fun!
Suvakas
- Maxigo_0.9.3c.zip
- Latest Maxigo for Indigo 09.
- (277.01 KiB) Downloaded 761 times
Re: Maxigo 0.9.3c
why that?suvakas wrote: * added - "Max Num of Consec Rejections" increased to 99999 (Advanced Setup rollout)
Re: Maxigo 0.9.3c
Someone requested it from me. I don't remember who though.manitwo wrote:why that?suvakas wrote: * added - "Max Num of Consec Rejections" increased to 99999 (Advanced Setup rollout)
Re: Maxigo 0.9.3c
Why not? xDmanitwo wrote:why that?suvakas wrote: * added - "Max Num of Consec Rejections" increased to 99999 (Advanced Setup rollout)
- Kosmokrator
I just discovered, that scenes that have been made using previous versions of Maxigo may crash when you open them with the latest Maxigo. I think it's because I changed the emitter material a bit in the newest version.
I'm not planning to roll back so it will stay like this. If you want to render the older scenes, then you have to merge the old files into clean scene.
- Kosmokrator
As always a Forum search would be faster than tipping your posting...damian wrote:Excause me. I dont Understand...((( I dont understand what is need for this exit portals?... many people talk about it and they are wondering it. But I dont understand... please - tell me more about it.
Sorry for english.
Check HERE for the Fryrender Exit Portal Dokumentation...
