How Do You Set Up A Exit Portal?
8 posts • Page 1 of 1
nakile
Post by nakile » Thu Jul 19, 2007 10:44 pm
I couldn't figure it out for the life of me.
I'm using Blendigo to set up me scene with a sunlight. I then cover up the openings with a mesh plane and set it to EXIT PORTAL. My end result is a pitch black scene with nothing visible.
Am I missing something obvious here?
Post by suvakas » Thu Jul 19, 2007 10:46 pm
The normals of exit portal must face inwards.
Flip the normals and see if it helps.
nakile
Post by nakile » Thu Jul 19, 2007 10:51 pm
Oh yes, those damn normals. :oops:
That fixed it rather quick. Thanks much. I've literally been kicking myself over this for a few hours.
Macrob
Post by Macrob » Wed Jul 25, 2007 2:33 am
Hi !
I have a room with a hole in the ceiling. The only lightsource is a sun. With exit-portal it is much slower than without.
I use blendigo, indigo_09_test3. The exit-portal is a plane (4 verticles) facing inwards.
Any ideas?
with exit portal
without exit portal
exit-portal setup
Post by OnoSendai » Wed Jul 25, 2007 2:34 am
try setting bidir = true
hybrid = false
Macrob
Post by Macrob » Wed Jul 25, 2007 3:23 am
Hmm, the fastest (in micro-seconds/sample) is all off, no exit portal.
"all off"
Post by OnoSendai » Wed Jul 25, 2007 4:06 am
The rate of reduction in noise is the important thing, not samples per second.
zsouthboy
Post by zsouthboy » Wed Jul 25, 2007 7:27 am
Yeah, you could be getting more samples per second, but they're being used on portions of the scene your camera can't see.
