Violet 0.3
Violet 0.3
Post by OnoSendai » Fri Jun 22, 2007 8:32 pm
Hi all,
I've put up an installer for the Violet Tone Mapper v0.3 'official' in the downloads section:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
All credit goes to Robin Davies (rerdavies) for this release, including the fancy installer program :)
Let me know if this installer works for you!
nik
P.S. Violet is open source, if you want to contribute, check out the dev forum:
http://www.indigorenderer.com/joomla/fo ... m.php?f=21
supraserv
Post by supraserv » Fri Jun 22, 2007 9:33 pm
Thanks a lot.
afecelis
Post by afecelis » Sat Jun 23, 2007 12:08 am
yes! 8) 8) 8)
filippo
Post by filippo » Sat Jun 23, 2007 12:40 am
wonderfull!!!
SimonLarsen
Post by SimonLarsen » Sat Jun 23, 2007 12:41 am
Great, but i don't get the installer thing?
It's 2 files?
Woulden't it be easier if it was just a zip? :roll:
Tato
Post by Tato » Sat Jun 23, 2007 2:21 am
how to run it under linux? thnx
Post by OnoSendai » Sat Jun 23, 2007 2:25 am
Tato wrote:how to run it under linux? thnx
Have a look in this thread: http://www.indigorenderer.com/joomla/fo ... php?t=1973
zuegs
Post by zuegs » Sat Jun 23, 2007 2:33 am
installs and works fine on my Vista Business :D
THX very MUCH :!:
[Edit] suggestion for histogram: i would prefer that the red, green and blue channel histograms are all aligned at bottom and mixed additively. So i can see which one looks over the top (dominating) to get a nice white-point. Btw... what's about a gray- or white-point picker to adjust white-balance???? :roll:
jurasek
Post by jurasek » Sat Jun 23, 2007 3:45 am
if u got wine package installed, try msiexec command.
greetz,
jur
Macrob
Post by Macrob » Sat Jun 23, 2007 4:00 am
Hi!
msiexec /i
did install Violet-3 but now this:
Linux (gentoo):
~/.wine/drive_c/Programme/Violet $ wine Vio*
err:module:import_dll Library vcomp.dll (which is needed by L"C:\\Programme\\Violet\\VioletToneMapper.exe") not found
err:module:LdrInitializeThunk Main exe initialization for L"C:\\Programme\\Violet\\VioletToneMapper.exe" failed, status c0000135
:cry:
Where can I get vcomp.dll ?
Post by CTZn » Sat Jun 23, 2007 6:38 am
Looks like it's related with Visual Studio Runtimes or something alike, sorry have no link.
Thx for Violet, I have a request for it: please allow unclamped values (in general), setting the current max value of the slider to the double of the user specified value, along with the reset button of course. With this disposition, the user can first approximate a value and then use the slider to tweak around.
There is no reason to clamp in Violet values that are not in Indigo, I feel really uncomfortable with that limitation and in some case can't get the desired result. Someone feeling the same ?
Wedge
Post by Wedge » Sat Jun 23, 2007 6:56 pm
I have not used any of these new Violet builds yet but the old one has a clamped tonemapping of 10 (or something around 10) that is usually lower than what I find myself using. This might be outdated by now, but it would be awesome to have the same input values as Indigo supports rather than sliders with much shorter ranges. :)
Thanks to all working with Violet, soon I hope to find time to try a newer build!
Post by CTZn » Sun Jun 24, 2007 1:49 am
@Macrob: hopefully the dll is in that package you may need:
http://www.microsoft.com/downloads/deta ... laylang=en
The fact is, I can't confirm it will work, but if I had your issue on Windows I would install that.
Thanks Wedge ;)
rerdavies
Post by rerdavies » Wed Aug 15, 2007 1:48 am
Macrob wrote:Hi!
msiexec /i
Linux (gentoo):
:cry:
vcomp.dll is the DLL that provides multi-threaded execution services for Violet. It's a Microsoft redistributable that's installed using Manifest linkage. Unfortunately, this seems to be a feature that's not supported by Wine. (Hence the disclaimer that the installer can't be used on Wine). The recommended solution is to use the LINUX-compatible build without multithreading.
Macrob
Post by Macrob » Wed Aug 15, 2007 4:50 am
rerdavies wrote: The recommended solution is to use the LINUX-compatible build without multithreading.
Which build? Of Violet? Where can I get it? On the donload page I find only one msi.
