Need a answer quick for 0.7 exporting
3 posts • Page 1 of 1
thunderthunder
Post by thunderthunder » Wed Jun 06, 2007 6:52 am
I have blender 2.44 windows and I need to know some of the best ways to export scenes with the 0.7 exporter. Every time I export a file the render process in indigo say computing bloom and the it just takes for ever to render a small sort-of-clear pic. Anyways need advise i'm doing this short animation want to have it finished by 6-14-07
matsta
Post by matsta » Wed Jun 06, 2007 7:49 am
um, you could always just turn bloom off? i'm not sure if you are using blendigo or not but it sounds like the thing you need. bloom is just beefed up lighting and is not necessary for most renders, normally only used for beauty renders. i suggest using blendigo especially if u looking to export many frames. get it here http://www2.indigorenderer.com/joomla/f ... php?t=1914
once u got it there are buttons under render settings for turning all that stuff on and off.
hope that helped
greetz
mat
EDIT: you say "sort of clear pic" like u dont know how indigo works. that first frame u see is almost always unclear... but the beauty is that the longer u leave it the clearer it gets, its not like other renderers (blender internal for example) which just render the image once and you get 1 "final" image. leave the render going once u have turned off bloom and u will see what i mean.
PS u may have known that, if so, apologies for the mistake.
Post by Kram1032 » Wed Jun 06, 2007 8:28 am
And why are you using 0.7?
Use 0.8, instead which more or less is an improved 0.7 ;)
Users browsing this forum: Google [Bot] and 69 guests
