by Kram1032 » Thu May 31, 2007 8:09 am
"requests"
- turn on Normalsmoothing on the eyes
- make the small one ONE multires layer less detailed and make it the "child"
-try to get the eyes more saurian looking (not that oval, but 2D-lens like)
- try to add a blend with an SSS mat and an alpha map (which has the wings beeing nearly fully SSS, while the body should be mostly as is... but nowhere fully one of these) [this is the 3rd hardest thing, I guess]
- try to add an exponent map: the crevices between the scales and the wings are not that specular, I guess [2nd hardest thing...]
- try to ridge it o.O [definately the hardest thing]
-maybe, you could make the eyes slightly red-glowing, but there is no need of this... a texture like that would be great...
I hope, you're good in ridging and UV-mapping xD
ok, the last three points (except the red eyes) are tricky and mostly need extreme specs on a PC, but maybe, you can get it work... would be great!
