[BUG] Indigo 0.8 stable null material shadows
15 posts • Page 1 of 1
Post by Zom-B » Thu May 17, 2007 11:40 am
Hey Ono...
It seems there is (still) a Bug with the null material in 0.8 stable.
I use a null material blended diffuse material (no bump) Hybrid + BiDir + MTL!
(540 mutations per pixel)
for everybody who can't see this, I raised the contrast in PS.
Here is the Scene File:
***EDIT***
I let the rendering stay over night, maybe this artifact is gone then...
I tried the same scene used diffuse transmiiter at 1000 Muts per pixel,
but no artifacts are visible...
null_mat_bug.zip
The scene Files
(2.44 MiB) Downloaded 221 times
Post by CTZn » Thu May 17, 2007 12:51 pm
I've noticed that in your earlier post. Just to support your report ;)
Post by Kram1032 » Thu May 17, 2007 4:27 pm
and I wrote a possible problem to your earlier post ;)
Post by suvakas » Thu May 17, 2007 7:29 pm
yep, i get the same kind of thing.
Post by OnoSendai » Thu May 17, 2007 8:16 pm
Ok, bug noted, thx.
Nice test scene :)
You should try doing a blend between phong and diffuse transmitter for the leaves (all blended with a null mat). I think it would look nice.
Post by Kram1032 » Thu May 17, 2007 8:22 pm
specular leaves :D
Post by Zom-B » Thu May 17, 2007 8:49 pm
A just rendered the Image for over night for 2200 mutations per Pixel, the bug is still visible...
But by exident I found the following strange shadow issue :?:
OnoSendai wrote:Ok, bug noted, thx.
Nice test scene :)
actually the idea was to do a blend, but using phong for some glossy reflections of the Ivy,
but I just tried diffuse_transmitter only to check the effect first, before blending... but this was the result :?
BTW Ono, if you like the scene, so just keep it :wink:
Post by OnoSendai » Thu May 17, 2007 8:50 pm
Oh yeah, I might download it for testing :)
Post by Kram1032 » Thu May 17, 2007 9:52 pm
that difference trick is good for checking :D
really strange shadow behaviour.
scyguo
Post by scyguo » Wed May 30, 2007 10:53 pm
hi
I've noticed same problem - looks like nools alpha bug
set: mlt+bdir+hybrid
env: sunsky
Post by Kram1032 » Thu May 31, 2007 12:17 am
are you also using 0.8, scyguo?
scyguo
Post by scyguo » Thu May 31, 2007 10:25 am
yes, official stable 0.8 - winxp64pro, latest blendigo mod from Bigfan and blender244
In 0.8 test3 there is another problem with nools alpha - object with blend nool behind another blend nool was invisible. In new official 0.8 this is solved - there is only that strange nools alpha or maybe something else. In my case it's not big problem - five minutes in pshop and done :)
Post by Kram1032 » Fri Jun 01, 2007 2:13 am
Hmmm...
I guess, maybe, it could help, to try different modes:
Try to deactivate Hybrid, I.e....
Maybe, that works.
I hope, Ono finds a solution, soon^^
Post by OnoSendai » Fri Jun 01, 2007 3:00 am
Yeah, you can probably work around the bug by turning bi-dir off
scyguo
Post by scyguo » Sat Jun 02, 2007 6:53 am
:) thanks!
It's working - renders are clear with bdir off - needs more time but it is no difference between nools alpha and background
thanks again!
