Homage to Nile
Homage to Nile
A simple column hall and the river Nile at the end of it. Started texturing it today. Find the textured detail
- columns.jpg (89.22 KiB) Viewed 9630 times
A bit of an update. Almost managed to get rid of the hard edged shadows on columns. I have a bit of trouble with .png format. It is not accepted by indigo (using 0.8 t 2) saying that the file is not proper png file. Tried to save from Gimp, ArtWeaver and even inkscape. Always the same.
Scaled down by 33%
Scaled down by 33%
- nil.jpg (146.55 KiB) Viewed 9204 times
Updated after a strong battle with bumps and normals. Will have to change the waves on the bases and stars to make them look less american.
As to the bumps and sharp shadows. This is all due to that bump and smoothing + sharp light can't stand each other. It probably appears in most of rendering apps but people seem not to spot this for some reason. I came across this problem on Maxwell forum today and it was raised by one of users, however also there it was not explained nor cure was suggested.
Indigo is awesome, I think.
- wet.jpg (111.41 KiB) Viewed 9048 times
I think, the ripples are just fine
but I'd like to see the floor and cbc
do you know, what's strange about that pic?
look "outside": you clearly can see a flash.
but there is an other way, to look outside:
Also those small, narrowl (argh, I can't find the word, atm
)s at the top give light.
And? It's blue! a fresh sky...
Maybe, there is a flash-exr somewhere out there, or you could add flashes, there, too...
you even could model a huge sphereoidish SSS-object, that more or less simulates storm-clouds
Users browsing this forum: DotBot [Bot] and 66 guests
