wine + indigo_08
9 posts • Page 1 of 1
kowalenzo
wine + indigo_08
Post by kowalenzo » Fri May 04, 2007 4:50 am
hi guys!
i have a problem with indigo_08 under linux... it seems that wine isn't able to handle it any more. i get this message:
err:module:import_dll Library MSVCP71.dll (which is needed by L"Z:\\home\\k\\Desktop\\indigo_08_test1\\indigo.exe") not found
err:module:import_dll Library MSVCR71.dll (which is needed by L"Z:\\home\\k\\Desktop\\indigo_08_test1\\indigo.exe") not found
err:module:LdrInitializeThunk Main exe initialization for L"Z:\\home\\k\\Desktop\\indigo_08_test1\\indigo.exe" failed, status c0000135
do you have any idea how to solve it? how can i install those libraries?
kowalenzo
joegiampaoli
Post by joegiampaoli » Fri May 04, 2007 5:06 am
Download from here:
http://www.dll-files.com/dllindex/dll-f ... ml?msvcp71
http://www.dll-files.com/dllindex/dll-f ... ml?msvcr71
Extract and copy them to your system32 folder of your .wine directory and that should be it.
Joe Giampaoli
My Indigo Gallery
kowalenzo
Post by kowalenzo » Fri May 04, 2007 5:21 am
there's no system32 folder in my wine dict, and all the files in my wine dict have *.dll.so extension. I put those 2 libs in my wine dict together with all the libs, and still get the same error message. but thanks for help anyway ;)
joegiampaoli
Post by joegiampaoli » Fri May 04, 2007 5:25 am
:shock: What??? :shock:
Ok here goes, to begin with is your wine directory hidden (does it have a dot before the folder name, are you looking for hidden directories?)
The path to the system 32 should be:
/home/yourusername/.wine/drive_c/windows/system32
you should see some dll files there......
What linux are you using by the way and what version of wine?
Joe Giampaoli
My Indigo Gallery
carbon
Post by carbon » Fri May 04, 2007 5:26 am
it is enough to put it into indigo directory
joegiampaoli
Post by joegiampaoli » Fri May 04, 2007 5:27 am
Ah yes also.... :roll: :roll: :roll:
Just trying to help in a way that if he runs another app with wine that needs the same dll files then he will get same error for that app.......
Joe Giampaoli
My Indigo Gallery
kowalenzo
Post by kowalenzo » Fri May 04, 2007 5:39 am
ok, thanks a lot guys, both solutions work perfect :-)
and forgive me being such a dumass in this area ;-)
DaveC
Post by DaveC » Sat May 19, 2007 11:18 am
I've got that same error, downloaded the .dll files, and copied them in to the system32 directory. indigo still refuses to run. what am i doing wrong?
dave@1[Indigo]$ wine indigo.exe
err:module:load_builtin_dll failed to load .so lib for builtin L"winex11.drv": libXxf86dga.so.1: cannot open shared object file: No such file or directory
err:imagelist:ImageList_ReplaceIcon no color!
Application tried to create a window, but no driver could be loaded.
Unknown error (127).
Anybody clever enough to help me? I'm running simplyMEPIS64 on an AMD Athlon 64 3500+ with 2 gigs of ram.
joegiampaoli
Post by joegiampaoli » Sat May 19, 2007 1:58 pm
Hi DaveC! ok, looks like libXxf86dga.so.1 is actually the problem there. I've never had an issue like this because I use ubuntu, still this might be a wine problem with libXxf86dga.so.1 are you using latest wine? I googled up for libXxf86dga.so.1 and some people report similar problems. Try newer wine 0.9.37 just to see. Go here:
http://www.winehq.org/site/download
Joe Giampaoli
My Indigo Gallery
Users browsing this forum: DotBot [Bot] and 32 guests
