Hearts
I like it, but you should change the white point...
Lord of the Rings Junkie
Check your normals !
1° the (circular and lateral) flat part of the rings looks inverted,
2° The bottom part of the "coockie" is showing some artefacts at the edges, either add more edge loops around the zone where it's touching the floor (prefered in your case) or separate the bottom part.
Apart the white point issue already mentionned, the image works good
Thx Kram for the incoming compliment
I'm sort of retired from 3d, got some training
