.:: Colored glass with bitmaps
Hi to all again...
Suvakas how can I make a colored transparent glass using a bitmap as colors... with your exporter for 3ds max?
probably Indigo don't have this option...
ah and Kosmokrator once did a fish-bowl with transparent colourmapped fish... (or?)
Edit:
http://www2.indigorenderer.com/joomla/i ... ewsIndex=1 - they have the power
http://www2.indigorenderer.com/joomla/i ... ewsIndex=1 - exotic fish
Edit:
they are
look at the top fin of the yellow fish.
It even looks like SSS, a bit, but the rays are passing linear.
I guess, it's Albedo
dunno, how/why it works, but both renders show THAT it works.
Ask Kosmokrator and enricocerica!
although, when I look at the frogs, I'm not 100% sure, if they're transparent...
the fish definately are, though
Oh, i see. I thought you were referring to the stamp on the light bulb and not the frogsKram1032 wrote: although, when I look at the frogs, I'm not 100% sure, if they're transparent...
I belive the fish image was exported with Maxigo and there is no way to do it in Max at the moment.
Here is the thread: http://www2.indigorenderer.com/joomla/f ... light=fish
Fishes have Phong material.
- Kosmokrator
- Kosmokrator
Ok. Now i get it - hey Kosmo, you're the one who doesn't like readme's right?Kosmokrator wrote:i dont know...maybe...but the curent indigo max exporter dont support the blend type mat...
Blend material is supported long long time already using standard max blend material.
Taken from readme:
* Use standart Max Blend material for Indigo Blend material.
And actually Maxigo has even a user friendly approach for blend maps allowing you to use alpha map directly from Phong and Diffuse map. Alpha map actually is a blend map too.
So.. Blend maps = supported
Suvakas
Ps. There also will be a separate Indigo Blend material type in next version that supports exporting the entire blend tree into *.igm file, but for now use the standard max Blend material...
- Kosmokrator
