render node
Come here for help & support.
7 posts • Page 1 of 1
jan1
render node
Post by jan1 » Thu Aug 19, 2021 2:26 am
Hello
i just bought 2nd pc and want to use it like render node for indigo , now i have full indigo, so i can use 2 render nodes
but i dont know what to do /in software way/ to make it work .
can u help me ?
burnin
Re: render node
Post by burnin » Thu Aug 19, 2021 8:46 am
For starters, have you helped yourself to...?
Indigo Manual: Network Rendering
jan1
Re: render node
Post by jan1 » Sun Aug 22, 2021 9:02 pm
ok i did it like tutorial said but it write something about unlicensed frame resolution , and it abort network rendering ,
so i have a question how to setup slave to render with license ? i have one full indigo 4.x.x license and it says i have two render nodes with it .
jan1
Re: render node
Post by jan1 » Tue Aug 24, 2021 5:20 am
Connected to render master.
Indigo Exception: Already failed loading this scene before, abandoning load. Previous error message: Aborting network render, image dimensions exceed unlicensed limit.
Connection to render master terminated.
jan1
Re: render node
Post by jan1 » Tue Aug 24, 2021 6:10 am
so does this means i have 2 render nodes but running only in free mode ?
and i have to buy render node licence to render with full resolution ?
juan_irender
Re: render node
Post by juan_irender » Wed Aug 25, 2021 6:24 pm
Hi jan1.
Every render node has its own licence key. You must activate each node with its key, in the licensing menu, section licence key.
Ciao!
C4D R18 Studio user
Blender user :D
jan1
Re: render node
Post by jan1 » Thu Aug 26, 2021 11:46 pm
ok i found way how to make it working ,
i just have to open indigo render on slave machine and put licence key there
then i have to run network slave and network manager and all is working now
ofc network rendering is quite slow in updating image , otherwise is good .
