.:: Exporter for MAX and scale...
3 posts • Page 1 of 1
tizxx
Post by tizxx » Tue Apr 17, 2007 1:34 am
Hi to all,
Suvakas, I not understand the correct scale of your wonderful exporter...
If i work in centimeters or meters the result is the same?
Is more probably that whai i say and write is wrong...
can you explain me How to setup a correct scene
with units in centimeters...
thank you very much in advance...
bye bye
TiZxx :D
Post by suvakas » Tue Apr 17, 2007 2:18 am
Hey tizxx !
Welll..Since Indigo uses meters, then you have to convert your units to meters...
for cm : 1m = 100cm, 1cm = 1/100m - scale should be 0.01
for mm : 1m = 1000mm, 1mm = 1/1000m - scale should be 0.001 (the default value in exporter)
I'm not sure if this whole scale thing works correctly in Maxigo....but i think it should.
tizxx
Post by tizxx » Tue Apr 17, 2007 2:28 am
Thank you very much.
