Chillin' in the Tub
eg2k6
Chillin' in the Tub
Post by eg2k6 » Tue Apr 03, 2007 11:19 am
i was testing reflections so i decided to make this:
"Chillin' in the Tub"
some guy sitting in a bowl of water. :)
DaveC
Post by DaveC » Tue Apr 03, 2007 11:48 am
Someone's having fun with their new toy (indigo). Good to see some real fun being had :D
eg2k6
Post by eg2k6 » Tue Apr 03, 2007 12:11 pm
yeah. im rendering some milk right now. :)
EDIT: milk isn't colorful enough. im doing juice.
DaveC
Post by DaveC » Tue Apr 03, 2007 12:14 pm
Are you copying stuff from my gallery? ;) I've done snowmen AND milk recently.
http://www2.indigorenderer.com/joomla/i ... temId=5324
Check toward the bottom of that page.
mrCarnivore
Post by mrCarnivore » Tue Apr 03, 2007 7:12 pm
You should subdivide a little more. Those black areas really are sooo easy to avoid and the result looks much better.
Funny image!
Stur
Post by Stur » Tue Apr 03, 2007 8:34 pm
No, you just need to activate normal smoothing.
Post by Kram1032 » Tue Apr 03, 2007 10:17 pm
Actually, it's a bit strange, that there ARE normalsmoothing problems with unsmoothed normals....
But I like it: It gives a toony effect :D
Post by OnoSendai » Tue Apr 03, 2007 10:29 pm
I think they're smoothed in some fucked up way
DaveC
Post by DaveC » Tue Apr 03, 2007 11:18 pm
I already said somewhere, just add an edgesplit modifier ;)
Post by Kram1032 » Tue Apr 03, 2007 11:23 pm
edgesplit will split edges (D'oh) and you have to be careful with subdiv, then...
If you FIRST do edgesplit and THEN subdivide, some faces will get round -> wont catch the other faces
Post by CTZn » Wed Apr 04, 2007 1:22 am
Maybe a lamina faces problem (2 triangles sharing 3 edges). Check for double geometry.
eg2k6
Post by eg2k6 » Fri Apr 06, 2007 3:24 pm
this image was mainly to test the water, not the material of the bowl.
here is a bowl of Cocoa Puffs i rendered a few days ago. the bowl has no problems here.
Post by Kram1032 » Fri Apr 06, 2007 10:59 pm
looks great!
The cocoa-milkish liquid should have
(@ manitwo: :oops: )
SSS ;)
DaveC
Post by DaveC » Sat Apr 07, 2007 3:22 am
yes. SSS. milk coloured brown :D ;)
eg2k6
Post by eg2k6 » Sat Apr 07, 2007 5:11 am
how do you add SSS?
