IndigoMax 4.4.14 Beta
10 posts • Page 1 of 1
Post by fused » Fri Sep 18, 2020 8:54 am
Supported max versions: 2015, 2016, 2017, 2018, 2019, 2020, 2021.
changelog wrote: 4.4.14
ActiveShade improvments.
Progressive material preview rendering.
Fixed plugin not shutting down properly.
Max 2021 support.
Discontinued Max 2013 and 2014 support.
Changed versioning to same as Indigo version.
Updated SDK to 4.4.14
wob
Re: IndigoMax 4.4.14 Beta
Post by wob » Fri Sep 18, 2020 10:01 am
wow
dr_zepsuj
Post by dr_zepsuj » Sat Sep 19, 2020 4:05 am
Hi! This is great, now I would appreciate if you could add some settings to the material preview rendering (quality, Open CL), next thing I would like to see is to bring in feature support in line with standalone renderer (looking at denoising). Thanks!
If its not broken - take it apart and fix it ! ;)
Post by fused » Sat Sep 19, 2020 4:11 am
The progressive materials previews are a little bit experimental and don't work very well with ActiveShade (I hope I'll be able to improve this).
Regarding material preview quality, what kind of "quality" are you talking about? Samples per pixel?
Denoising will be added also, all in it's time. :)
Yves
dr_zepsuj
Post by dr_zepsuj » Sat Sep 19, 2020 10:53 pm
Yves
Thanks for your reply! Yes, I meant samples per pixel. I also think material preview should use currently selected render mode (Path tracking/bidir etc, and also Open CL if selected) This would help with designing materials. As an example in my workflow, OpenCL is the only way forward due to performance, but not all material features are available in this mode and it would be great if the preview reflected this.
Also, sometimes, material preview turns grey and only solution to this seems to be 3d max restart.
dr_zepsuj
Post by dr_zepsuj » Tue Sep 22, 2020 10:28 am
Since I am already here... there is a very useful function in 3d max, if you select an object (or several) and go to properties, there is a parameter called "visibility", it can hide the object and is animated. It is very handy, but it does not work with Indigo... object with "0" visibility is still visible when rendering in indigo. I know I can hide things manually, but it makes the workflow extra painful when working with multiple objects in animation ;) I would highly appreciate even a basic implementation of this feature!
Also, there is/used to be max material called shadow/mate this captured shadows, but not alpha channel, so one could have png with transparent background and rendered shadows :idea:
Post by fused » Wed Sep 23, 2020 11:47 pm
Thank you for the feedback!
Also, sometimes, material preview turns grey and only solution to this seems to be 3d max restart.material-error.png
Regarding this, the preview renderers are kept alive for 30 seconds after the material was last update and the render completes (possibly also due to an error, I ran into this issue a couple of times). So eventually, it *should* recover, maybe no need to restart max.
But I'll also be looking into this.
dr_zepsuj
Post by dr_zepsuj » Thu Sep 24, 2020 1:50 am
It happens quite often, especially when enabling, disabling and replacing texture maps on the material
MrBlack
Post by MrBlack » Sat Oct 03, 2020 7:19 pm
Did someone say a new version IndigoMax?
Thanks a million.
I was starting to think Max was going to be abandoned.
Jay-ko
Post by Jay-ko » Wed May 05, 2021 7:42 pm
Please add the 3ds Max 2022 version.
errare humanum est
Users browsing this forum: No registered users and 77 guests
