Blendigo 4.3.0 - Blender 2.8
Post by fused » Tue Mar 03, 2020 5:08 am
Thank you to MZ for all the work of porting Indigo to Blender 2.80!
Blender 2.80-
Archive: https://downloads.indigorenderer.com/di ... master.zip
Windows Installer: https://downloads.indigorenderer.com/di ... taller.exe
Blender 2.79
Archive: https://downloads.indigorenderer.com/di ... 1-2.79.zip
Changelog:
4.3.0
* Blender 2.8 support
* Bugfixes
Re: Blendigo 4.3.0 - Blender 2.8
Post by fused » Wed Mar 04, 2020 1:47 am
Added links to Blender 2.79 builds and some minor fixes for installer issues.
wob
Post by wob » Sun Aug 02, 2020 1:00 am
nice! will test with 2.9
marcbartels
Post by marcbartels » Thu Aug 06, 2020 7:49 am
Is there any chance to have a viewport render mode like LuxCore has?
Or is that technically impossible?
I would expect a simple yes/no answer.
schwungsau
Post by schwungsau » Thu Sep 24, 2020 3:01 am
it’s possible but its takes deep dive into c++ sdk. it a lot of work.
currently its bunch if python scripts for exporting
FakeShamus
Post by FakeShamus » Tue Oct 06, 2020 2:30 pm
Hi, I get this error when I try to export a scene: Export > Indigo Scene (I know most people just use the regular render button, which works fine, but I have an old habit of exporting the scene and then running Indigo separately...)
Same error with both Blender 2.83 and 2.9
  File "C:\Users\Shamus Clisset\AppData\Roaming\Blender Foundation\Blender\2.90\scripts\addons\indigo_exporter\operators\__init__.py", line 554, in execute
    return super().execute(context.scene)
TypeError: execute() missing 1 required positional argument: 'depsgraph'
vis4arch
Post by vis4arch » Sun Dec 20, 2020 4:16 am
is an indigorenderer blender exporter for mac is available or not?
all the best,
tamas
berg8 - werbeagentur
. design . web . marketing .
burnin
Post by burnin » Sun Dec 20, 2020 12:01 pm
well, It's a Blender python add-on which should work w/ any OS
do check and report your findings :)
FakeShamus
Post by FakeShamus » Mon Dec 21, 2020 3:37 am
Hi, I'm having some other issues when trying to render an animation using motion blur - I get errors that a certain igmesh is being used by another process, or that a certain material is not defined. When I turn off motion blur the frames render without errors. I'll try to capture the exact error text next time and post here, but I am in the middle of a deadline so I had to just move ahead without motion blur on this one. This is with Blender 2.9 and Indigo 4.4.14 on Windows 10...
dafassi
Post by dafassi » Fri Mar 19, 2021 12:00 am
Hey there!
Can you help me with this things:
1- How can i enable denoising using the Blendigo-Addon? I need it for animation export. Or is there a way to set it in Indigo-Renderer as enabled by default?
2- Is there a way to export a frame but keeping all the settings that are done before inside the Indigo-Renderer?
As example i export one frame, setup materials etc and save it. And when i hit export again i would like to not overwrite all settings. If this would work for all frames that would be helpful.
3- When using a hemi-sun to set an environment image it is rotated by 90° by default. Seems to be an export-bug. Just to let you know ;)
Post by StompinTom » Fri Apr 09, 2021 11:25 pm
Hi @MZ and @fused,
A while back I played around with integrating the Indigo SDK with Blender through Ctypes with some pretty neat results. I know that the licensing issues prevent that from being an official add-on - which is a shame, because that would be the way to get a very tight integration into viewports, etc. - but one thing that might be useful from it is a way to compose materials in the node editor. I notice that in Blender 2.9x the focus is almost completely on using nodes for materials, so even the texture panel is not used anymore, which makes it a bit counterintuitive to apply textures and such.
If it sounds useful, I can upload the code for the node-based system? It basically lets you use the shader node system for making Indigo materials and export them, so maybe a good addition to the current Blendigo...
Post by StompinTom » Sat Apr 10, 2021 1:15 am
This is what the nodes look like currently. The nice thing is that you could have Indigo nodes side-by-side with normal Blender / Cycles nodes, to make it easier to switch back and forth, or share image textures.
ones_and_zeros
Post by ones_and_zeros » Tue Apr 13, 2021 7:38 am
New Indigo user here. I recently bought a license of Indigo to use primarily for Blender. I'd love to be able to use indigo with this workflow.
maXemaeLean
Post by maXemaeLean » Sat May 01, 2021 1:43 am
If it sounds useful .. It basically lets you use the shader node system for making Indigo materials (and export them) ..
.. 'sound useful' ??..
I would LOVE it! :D
Blender 2.79b & 2.92 | Blendigo 4.3.0 | Indigo RT 4.4.18 | Windows 64bit
maXemaeLean
Blendigo 4.3.0 issues
Post by maXemaeLean » Thu May 06, 2021 1:40 am
.. I get this error when I try to export a scene: Export > Indigo Scene
Yep, same here when trying to export from Blender 2.92.
The version for 2.79 seems to work fine. (I usually export via Render-button.)
Hi @fused
Both versions of Blendigo (for 2.79 & 2.8) don't write the <splat_filter>-tag into the .igs-file.
So always fastbox (Indigo 'default'?) is used (and will be added, when re-saving the .igs from within Indigo. Has then to be changed manually).
Users browsing this forum: Google [Bot] and 18 guests
