Hello,
I am trying to render a hefty scene on my Macbook. I figured GPU rendering would speed things along, but when I turn it on, Indigo gets stuck on the "building" part and goes nowhere. Any ideas would be much appreciated.
Best regards,
Erich Boehm
Indigo's GPU rendering not working on Macbook Air mid 2015
ErichBoehm
Re: Indigo's GPU rendering not working on Macbook Air mid 2015
Hi Erich,
Intel HD Graphics really do not work well with Indigo. It would probably be slower than the CPU.
Best,
Yves
Best,
Yves
- schwungsau
even macbookpro GPU are slower then the CPU. you wanna have GPU speedup you need get a soild graphicscar
as eGPUd.macbook GPU+CPU does gain much more speed either.
ErichBoehm
Does Indigo support eGPUs? Here is the product I am considering purchasing
https://www.powercolor.com/product?id=1545120465
Hi
Gigabyte Gaming box RX 580 8 g scheda grafica Egpu (gv-rx580ixeb-8gd)
474,11 € https://www.amazon.it/Gigabyte-Gaming-s ... B07CCK527Y
PowerColor Mini Pro RX570 8GB eGPU Thunderbolt3
$479.99 > €432,577 https://www.amazon.com/PowerColor-Mini- ... B07Q4R7GZR
I think the first solution is more convenient because in addition to greater computing power, the power supply is internal.
Best regards
Best regards
ErichBoehm
My Macbook has Thunderbolt 2. Would this work if the solution is Thunderbolt 3? Would the two be backwards compatible?
- Originalplan®
Hey Erich, short awnser ≠ YES!ErichBoehm wrote: ↑Wed Sep 04, 2019 5:42 amMy Macbook has Thunderbolt 2. Would this work if the solution is Thunderbolt 3? Would the two be backwards compatible?
( if you plan only on rendering it will work fine, for gaming it wont bcs of lag, you need TB3 for that )
All you need to do is get an Apple adapter TB2 to TB3 and off you go.
https://www.apple.com/mx/shop/product/M ... nderbolt-2
Users browsing this forum: Ahrefs [Bot] and 13 guests
