by zeitmeister » Sun Aug 11, 2019 8:08 pm
Very cool; thanks for fixing the image buffer issue!
Arkon
by Arkon » Thu Aug 15, 2019 12:27 am
Hello )
That's what I still have
by fused » Thu Aug 15, 2019 8:14 pm
Arkon wrote: ↑Thu Aug 15, 2019 12:27 am
Hello )
Hi Arkon,
that error means you don't have enough memory to render the image. Try using a lower super sampling factor (with every increases of 1 in super sampling, the memory needed to render the image increases by some factor).
Best,
Yves
rivera-b
by rivera-b » Mon Aug 19, 2019 3:09 am
Hello.
Trying to use this version.
Will not process sample scenes.
Using latest skindigo...
Will not process a simple rectangle scene.
Previous versions did well with sample scenes.
MacBook Pro (Retina, Mid 2012)
2,3 GHz Intel Core i7
8 GB 1600 MHz DDR3
by Zom-B » Mon Aug 19, 2019 8:04 pm
Hey rivera-b,
try disable your HD Graphics 4000 for GPU rendering!!
Its usually only causing issues due to driver support of OpenCL and in older working Indigo versions it slowed down the render for sure, go back and test it.
rivera-b
by rivera-b » Sun Aug 25, 2019 6:01 am
I did.
Thank you.
I will stop using the Mac for this and start training with the Windows + Quadro4000.
schwungsau
by schwungsau » Wed Oct 23, 2019 6:21 pm
i have new workstation with RTX5000 and kubuntu... indigo render does find the card.... it lauches and tell in render settings no openCL device available.?
by Zom-B » Wed Oct 23, 2019 11:34 pm
Latest drivers?! what version do you have installed...?
schwungsau
by schwungsau » Thu Oct 24, 2019 4:07 pm
yep, driver 435.21.... other render packages working fine with the GPU
by Zom-B » Thu Oct 24, 2019 7:59 pm
Hmmm, can you run this command and paste the output:
440 Drivers have been just released recently for Windows.... lets hope they hit Linux soon too
schwungsau
by schwungsau » Fri Oct 25, 2019 6:26 pm
i got
Error while loading scene: Failed to open file '/home/heribert/software/IndigoRenderer_x64_v4.2.25/--gpu__info': No such file or directory
No Metadata
all command flags are working. its a dual boot if lunch indigo under windows 10 pro it works i can use the GPU.
by Zom-B » Fri Oct 25, 2019 9:51 pm
Hmmm, your gpu info command has two _ _ instead of one, I'd say you set this command wrong, but am no Linux guy to tell how to do...
Have you tried the latest 4.4.1 beta if it does render?
viewtopic.php?f=1&t=15253
schwungsau
by schwungsau » Sat Oct 26, 2019 3:45 pm
4.4.1 does work, becaus it can find intel denoise libraries
./indigo_console: error while loading shared libraries: libOpenImageDenoise.so.0: cannot open shared object file: No such file or directory
4.2.25 give this gpu_info outout:
OpenCL info:
Successfully loaded OpenCL functions from libOpenCL.so
Num platforms: 1
============================Platform ============================
platform_id: 140374376330560
platform_profile: FULL_PROFILE
platform_version: OpenCL 2.0 beignet 1.3
platform_name: Intel Gen OCL Driver
platform_vendor: Intel
platform_extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_3d_image_writes cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_spir cl_khr_icd cl_intel_accelerator cl_intel_subgroups cl_intel_subgroups_short cl_khr_gl_sharing
beignet-opencl-icd: no supported GPU found, this is probably the wrong opencl-icd package for this hardware
(If you have multiple ICDs installed and OpenACL works, you can ignore this message)
clGetDeviceIDs failed
by Zom-B » Sat Oct 26, 2019 5:41 pm
as you see only some integrated Intel GPU gets found by Indigo, here is my output as an example:
Successfully loaded OpenCL functions from OpenCL.dll
OpenCL dynamic lib path: C:\WINDOWS\SYSTEM32\OpenCL.dll
Num platforms: 1
platform_id: 82146768
platform_version: OpenCL 1.2 CUDA 10.2.87
platform_name: NVIDIA CUDA
platform_vendor: NVIDIA Corporation
platform_extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics
1 device(s) found.
----------- Device 0 -----------
Device id: 82147248
device_type: CL_DEVICE_TYPE_GPU
device_name: GeForce GTX 1080 Ti
driver_version: 440.97
device_profile: FULL_PROFILE
device_version: OpenCL 1.2 CUDA
device_max_compute_units: 28
device_max_work_group_size: 1024
device_max_work_item_dimensions: 3
device_image2d_max_width: 16384
device_max_constant_buffer_size: 65536
Dim 0 device_max_num_work_items: 1024
Dim 1 device_max_num_work_items: 1024
Dim 2 device_max_num_work_items: 64
device_max_clock_frequency: 1683 MHz
device_global_mem_size: 11811160064 B
Users browsing this forum: No registered users and 121 guests
