I rendered this simple test scene to see how GPU Pathtracing would compare to CPU rendering, BIDIR MLT in this case.
My interest was mainly to see evaluate difference between dispersion and caustics.
Both images rendered for 40 minutes.the light source is a HDRI with many small light sources and the material of the twisted ring is the Lead Crystal from the online material DB with couchy B enabled.
The GPU renderer is nobly cleaner and the caustics are clearly visible. Nice!
However, there are dark areas mostly visible in the GPU render in in the left part of the image in the outer edges of the twisted torus. Those are not present in the CPU render. I checked the other CPU render modes as well (just not for 40 minutes) and these dark areas are not present in those render modes either..
Thoughts ?
Visible difference between GPU and CPU renders
Re: Visible difference between GPU and CPU renders
Hi
the second image is the best overall; which gpu did you use?
By default the GPU pathtracer uses a path depth of 8. It can lead to darkeing in certain areas, especially with specular materials. You can turn up the depth and the dark spots should get lighter or disappear completely (but it will also render a little slower).
@fused
Thanks for the tip. increasing Path Depth does indeed eliminate these dark areas. it's just not a setting available in the Blendigo UI (or I simply have to look harder ):
@Contefugo:
All of these images have rendered for 40 minutes on a 2017 MacBook Pro with a Radeon Pro 560.
This is not usually how long you want to wait for a GPU render, but these serve as experiments for me to determine the best render set up for my situation. At this time I think I'll invest in a eGPU to complement my notebook.
@Contefugo:
- pixie
Well, the thing is, specular materials and caustics always tend to take a lot more to denoise then simpler materials.
wow I just found out about this option, why not add to faq? to make new indigo users understand
popular render engines have video instructions, this will all help make friends with this wonderful render engine
Users browsing this forum: No registered users and 135 guests
