stains on transparent glass
Come here for help & support.
11 posts • Page 1 of 1
Kroustinio
Post by Kroustinio » Mon Apr 08, 2019 11:32 pm
hello,
can you tel me how to fix the problem of stains that appear on windows in my render ?
It's seems to happen in the dark parts of the scene, where are shadows...
this image was rendered with 20 000 samples per pixels. I think more samples would be better, but I'm not sure.
Thanks for your suggestions and forgive my approximative english.
Re: stains on transparent glass
Post by Zom-B » Mon Apr 08, 2019 11:37 pm
You took some glass from the Material Database?!
Use architectural glass for such windows!
It also seems you rendered with MLT, right? Use it only in special cases where you know what you are doing, stick to BiDir on CPU or PT if you have a beefy GPU :)
Kroustinio
Post by Kroustinio » Mon Apr 08, 2019 11:40 pm
it is quite strange : I show you this previously rendered image with a limit of only 15 000 sample per pixels, wich was perfect.
On the other hand the HDRI image is not the same.
Kroustinio
Post by Kroustinio » Mon Apr 08, 2019 11:45 pm
thanks for your answer : yes I used indigo MDB glass material.
What do you mean by architectural glass ?
What is MLT ?
the images where rendered with Ranch Computing render farm
Kroustinio
Post by Kroustinio » Mon Apr 08, 2019 11:46 pm
both glass canopy material are the same in this renders
Post by Zom-B » Tue Apr 09, 2019 12:01 am
MLT = Metropolis Light Transport, a render mode that Indigo supports.
It superior in certain fields but usually not for interior rendering.
Be sure to use PathTracing with BiDir
Arch Glass is Glass that lacks refraction. Its used for plane windows to have faster rendering.
It should be a checkbox for a specular material, depending on your 3D program...
Don't use it for Glass objects like the drinking glass on the table
The material you use from the MatDB has either some SSS enabled or cauchy_b value above 0.
Kroustinio
Post by Kroustinio » Tue Apr 09, 2019 12:15 am
Just checked : I used th Bidirectionnal Path thracing in Indigo. No Mlt
I think I will try to improve the level of SPP in the rendering farm, just to be sure.
But it's expensive !
Post by Zom-B » Tue Apr 09, 2019 12:21 am
Try the attached Material for your Windows and the shelf, it should fix the stains.
ArchGlass.zip
(464 Bytes) Downloaded 703 times
Kroustinio
Post by Kroustinio » Tue Apr 09, 2019 12:26 am
thanks, but if no reflections : no realism ?
Post by Zom-B » Tue Apr 09, 2019 12:38 am
it misses refraction.... not reflections. Test it!
Kroustinio
Post by Kroustinio » Tue Apr 09, 2019 12:43 am
Ok, thanks, Zom-B
