Hi everybody,
is there a way to set two different uv mapping on one single object with a blend material? as for example a brick wall as material 1, a painted text for material two and to move the text on the wall with an uv offset, etc etc?
thank you all by advance.
2 uv sets on 1 object?
Re: 2 uv sets on 1 object?
Hey Tyler,
afaik Indigo does support multiple UVs on single object, but this feature also needs to be supported by the exporter.
For C4D this feature is on the request list, but not included yet.
thanks Zom-B,
ok, i don't know how i'm gonna trick that. I'm really surprised this feature is not in c4d/indigo, that's a basic.
anyway
thank you
anyway
thank you
- zeitmeister
Well C4D itself is very basic regarding multi-UVs... it’s not the fault of the exporter.
BTW: I tested multi UV, and it seems to work! See attached testscene
Way more interesting for me at least would be support of the projector Shader where you can apply a different UV mapping for each channel of a material, great to create some complex blends for terrain and stuff
- multiple_UVs.zip
- (382.27 KiB) Downloaded 898 times
- Polinalkrimizei
Wow, I almost thought that I finally found a feature that Blendigo has, but the C4D exporter not!
- pixie
Zom-B wrote: ↑Thu Jan 03, 2019 4:34 amBTW: I tested multi UV, and it seems to work! See attached testscene![]()
- pixie
The blend map is tied to the size of the actual uv map so it repeats, but you can change the size of either grass so they fit one another.
Btw I tried the original sun+sky environment so I could get some turbidity but it ain't implemented yet on GPU.
- GRASS.pigs
- (8.45 MiB) Downloaded 752 times
Users browsing this forum: No registered users and 64 guests
