[BUG] Indigo camera tag in C4D R19
- Peacemaker69
Hello there,
I'm reporting a "bug" for camera tag information in C4D R19. While installing the last update from C4D to v 19.068 the camera tag with information it is simple disappeared. I try to disable all plugins except Indigo and still doesn't work.
The Indigo camera tag work well in C4D R18 version
Did anyone notice this bug ? Any help ?
Thanks,
Thanks,
Re: [BUG] Indigo camera tag in C4D R19
is this happening with the latest Indigo for C4D 4.2.22?
And is this only for existing scenes or for new scenes as well?
I tried 19.068 and I cant reproduce that bug. Can you check the C4D console if it gives any hint about what could be going wrong?
- Peacemaker69
Thanks fused for reply,
It have some error...
Seems like a conflicting plugin. Or maybe there are parts of an old Indigo for C4D installation hanging around. Make sure there aren't and if you can find out what plugin is conflicting that would be very helpful, too.
I can probably fix this by renaming it to TIndigoCameraTag (which it really should be anyway).
- Peacemaker69
Hi fused,
I've try to rename manually inside the folder Indigo for Cinema 4D and with no success... Still the same problem. Is it there any option inside C4D to change the name ?
- Peacemaker69
Hi Fused,
I found where is the problem. Conflict with another plugin called "U-Render"... I have deleted and now camera tag showing all information
Ah ok, good to know.
It's on the bugtracker, will rename the resources to contain "Indigo" in the name to avoid conflicts.
- Peacemaker69
