by fused » Wed Nov 14, 2018 5:02 am
by pixie » Wed Nov 14, 2018 5:12 am
Thank you Yves!
thesquirell
by thesquirell » Thu Nov 15, 2018 4:30 am
Thank you for this update!
Multi-instance mode for instances is omitted in this release, I guess. Never mind, your exporter exports instances faster then the native C4D's engine, lol.
by fused » Thu Nov 15, 2018 4:46 am
Not entirely sure if you are kidding or not
cindigo usually seems really slow to me.
But yes, multi instances are not supported yet. But I might have a crack at it soon.
thesquirell
by thesquirell » Thu Nov 15, 2018 10:53 pm
Well, I guess speed is a relative concept. I find it pretty speedy, kidding you not, Sir!
Multi-instances would be interesting to see, solely on the side of C4D's scene management. It can get tricky when you start to deal with tons of vegetation, grass, pebbles etc.
by pixie » Fri Nov 16, 2018 1:09 am
It would be swell if one could use the gfx card for previewing the materials, or having at least a switch to set it default.
by fused » Fri Nov 16, 2018 3:51 am
pixie wrote: ↑Fri Nov 16, 2018 1:09 am
I didn't do that because the OpenCL kernel compilation was so slow. Turns out we used outdated drivers for a long time haha. Definitely considering that for the next release.
by fused » Fri Nov 16, 2018 4:20 am
Added mac builds, including R20.
by pixie » Fri Nov 16, 2018 4:36 am
Sweet!
mpro31
by mpro31 » Fri Nov 16, 2018 5:04 am
Hi, I would like to know if there are any plans for improving IPR since is not yet fully responsive and slower than standalone version.
Phoenix
by Phoenix » Fri Nov 16, 2018 6:30 am
Hi Yves,
thank you very much for the new release and with it the R20 support.
But why is the following?
fused wrote: ↑Wed Nov 14, 2018 5:02 am
* Removed depth and mat id pass
Kind regards,
Tom
by fused » Fri Nov 16, 2018 12:27 pm
Phoenix wrote: ↑Fri Nov 16, 2018 6:30 am
Hi Yves,
Kind regards,
Tom
Hi Tom,
because Indigo has render channels now that do that (and more):
https://www.indigorenderer.com/document ... r-channels
mpro31 wrote: ↑Fri Nov 16, 2018 5:04 am
That is somewhere on the roadmap, yes.
by pixie » Sun Nov 18, 2018 11:01 pm
Could you put a switch in the light tag so that one could choose between a diffuse/null material? I usually use it so I can better hide the shadows in some fill light I create in a scene. This way the object emitting light don't have it's own shadow casted.
by pixie » Mon Nov 19, 2018 11:59 pm
One cannot generate IES previews
Error: Failed to create render output directory: Failed to create directory 'C:\Program Files\MAXON\CINEMA 4D R15\plugins\Indigo for Cinema 4D\preview\renders': Access is denied. (code 5)
