Some latest work...
JungleKing
Some latest work...
Hello to the community!
Since I use Indigo for more than several years, but actually didn't post anything.
Decided to share with everybody some of my latest work.
Thank you for any comments in advance!
Re: Some latest work...
Nice images @JungleKing thanks for sharing these!
What Hardware are you using for rendering, what are your rendertimes?
JungleKing
Hello kscore and thank you!
Since I didn't have the proper GPU for rendering these. It was done in more conventional manner.
With CPU i7 6700k and BiDir PT with exit portals, it was left to work for around 15-16h. I didn't really check the progression, it was rendering in the time when I usually leave my office to tomorrow morning.
Thanks for these informations. What software are you working with? You are welcome to post more often.
JungleKing
You are welcome.
I use Sketchup for modeling, and my work as an architect is primarily focused on getting architectural stuff done.
Most of the projects I was invloved in didn't require rendering, just Sketchup modeling. These were the projects I rendered in the past two months (and the only ones this year so far), and things may chagne, but certanly I will share more from now on when I have something good.
Awesome interiors, I love it! Did you tried any other software besides SkechUp?
JungleKing
Hello Benjamin. Thank you for your response!
To answer your question, I have tried some other modeling software, mainly 3ds max and Archicad, but it was just for some time. I discovered Sketchup 11 years ago and since I could do everything that I need when I started modeling for fun I stick with it.
Later when I used it for architecture, only few stuff was really hard to achieve and I made them possible via other plugins for Sketchup. And therefore since I could now make everything that was required and I was most familiar to work within Sketchup (also very happy with Sketchup modeling speed) I still mainly use that.
Thanks for reply, I'm pretty new in 3D design, working now at my first project. Good luck with your work
JungleKing
Thank you Benjamin! And good luck to you too!
JungleKing
very cool!
JungleKing
Condo Master Bedroom Interior.
With a new computer, testing to see how it performs.
