Realistic concrete-like tiles material
Come here for help & support.
4 posts • Page 1 of 1
redhot2
Post by redhot2 » Thu Feb 22, 2018 9:24 am
Hi guys. I've got problem with setting up material for my project. What tricks you use to achieve high detail surface on similiar type bathroom tiles? I've tried mostly Phong and little bump on same texture, couple ior, rougness setups. Nothing even similiar to real/expected effect. I'm stucked. Attaching textures and my poor try (rendered for couple minutes).
My goal is to achieve glossiness and slightly rough surface with all micro details
This tile is desribed by producer as semi matt material.
I've achieved quite nice effect but weird refflections using 3,5 IOR 0,5 roughness but I cant extract more details (too much IOR? poor light setup?)
Any ideas? Maybe blending materials or coating? Bump,normal maps (and what settings I should use)?
Thank you kindly for any advices tutorials.
Im using OPEN CL Path Tracing. No IES, only one layer of light
Re: Realistic concrete-like tiles material
Post by Pibuz » Thu Feb 22, 2018 9:39 pm
Hi redhot, I don't know if it's me but I can't see any images...
redhot2
Post by redhot2 » Thu Mar 01, 2018 4:03 am
Right click and opening in new tab works for me
Post by Pibuz » Thu Mar 01, 2018 4:22 am
Ok I was able to see the images.
i think that to clearly study the material, yuor scene must be waaaaaay too simple.
Also, the wide camera angle doesn't help understanding the behaviour of the subject.
I suggest you try to apply it on a floor, make a lightsource the opposite side of the camera, add a couple more lights on separate layers for adjustments on-the-go and render!
