Moneda de mi pais (Currencies of my country)
11 posts • Page 1 of 1
jansan
Post by jansan » Tue Mar 13, 2007 12:24 am
These currencies as a sample of the currencies of my country Indigo 0,7 t5 (export Blendigo) 30 min Laptop Dell Inspiron 9400 dualCore 2,16 Ghz. 4 threads
Estas monedas como una muestra de las
monedas de mi pais
Indigo 0.7 t5 (export Blendigo)
30 min Laptop Dell Inspiron 9400 dualCore 2.16 Ghz.
4 hilos
Post by OnoSendai » Tue Mar 13, 2007 12:40 am
depth of field!!!!
dougal2
Post by dougal2 » Tue Mar 13, 2007 12:44 am
to me the coins look like they are HUGE, probably because of your floor texture.
I think changing the floor to be more like a wooden desktop textuere, or a paper texture or something, along with a little DOF would help the believability (is that even a word?) of this scene.
Right now, even though the materials look about right my eye doesn't quite believe what it's seeing due to the realtive scaling of the floor texture
DaveC
Post by DaveC » Tue Mar 13, 2007 1:47 am
They do look huge. It would also be quite cool if the textures weren't just image maps. There's no bumpiness to them.
Post by Kram1032 » Tue Mar 13, 2007 3:39 am
dougal2 wrote:to me the coins look like they are HUGE, probably because of your floor texture.
Or just make the tiles wider...
DaveC wrote:There's no bumpiness to them.
Yes... would be nice to see bumpmaping with gold and silver.nk (although it doesn't really look like gold+silver...)
If you use DoF, you also can hide this problem with the two coins, with the number-side up: They're looking identical!
jansan
Post by jansan » Tue Mar 13, 2007 8:23 am
Thanks for their observations, Increase the tiles, change to the light to sun dof is not appraised being a very near Vista, as I can reduce the rank of which this in center, (I have fstop in 1 and I do not have To pressed and defocusing in the currencies is not even seen)
Gracias por sus observaciones,
Aumente los tiles, cambie la luz a sun
El dof no se aprecia por ser una vista muy cercana?, como puedo reducir el rango de lo que esta en foco, (tengo fstop en 1 y no tengo A pulsado y aun no se ve desenfoque en las monedas)
Post by Kram1032 » Tue Mar 13, 2007 8:39 am
sorry... didn't really get, what you mean... english plz ;)
f-stop should be as high as possible form much DoF...
At least Blendigo-tooltip says so...
The floor isn't really better...
It looks like big stones
search for a more wood-like map or strongly increase the scale of the texture! all the coins can be on a single stone!
maybe you need a higher res tex...
this one is blurry and the colours aren't plaed correctly...
jansan
Post by jansan » Tue Mar 13, 2007 8:57 am
Thanks for its observations, dof is not appraised being a very near look?, as I can reduce the rank of which this in center, (I have fstop in 10) and does not even notice the defocusing also with 1 and in the currencies dof is not appraised
(tengo fstop en 10) Y aun no se nota el desenfoque
jansan
Post by jansan » Tue Mar 13, 2007 8:58 am
Sorry re- send
Post by Kram1032 » Tue Mar 13, 2007 9:05 am
Yes, I have some probs with f-stop too...
1 => nearly black... So I think, apertude is much too small...
64 (max) => enough light but not even a bit DoF... :?:
Post by suvakas » Tue Mar 13, 2007 9:12 am
Check your scene scale and use greater f-stop (should get quite good defocusing with 2.8 - lets way more light in than 10)
Suvakas
