Indigo for Revit 2018
Announcements, requests and support regarding Indigo for Revit
14 posts • Page 1 of 1
Juju
Post by Juju » Tue Jan 23, 2018 2:06 am
Any idea when Indigo for Revit installer will have the install option for the 2018 version?
Nikolaj Knudsen
Re: Indigo for Revit 2018
Post by Nikolaj Knudsen » Fri Feb 09, 2018 7:13 pm
Hey all
Any news about the 2018 plugin? I have a project coming up in Revit 2018 soon, need to plan a workflow ahead :)
Nik
Post by OnoSendai » Mon Feb 12, 2018 11:05 pm
We are working on a Revit 2018 build currently.
merca1
Post by merca1 » Thu Mar 08, 2018 5:21 am
Hi
This plugin would be AMAZING right now - any idea when 2018 will be ready?
Post by fused » Thu Mar 22, 2018 5:28 am
sorry for the long dealy. You can find the 2018 plugin here: https://www.indigorenderer.com/forum/vi ... 38&t=14791
Nikolaj Knudsen
Post by Nikolaj Knudsen » Fri Mar 23, 2018 9:48 pm
Great! :)
merca1
Re: Indigo for Revit 2019
Post by merca1 » Wed May 02, 2018 9:30 pm
Sorry to ask the obvious question but when will you add support for Revit 2019!
Keep up the great work - Thanks
Nikolaj Knudsen
Post by Nikolaj Knudsen » Thu May 03, 2018 11:35 pm
I have a small problem with the exporter:
Render settings are not stored. Quite annoying on bigger cases. Can't pick other than first camera for instance.
Nik
Post by fused » Tue May 15, 2018 6:33 am
There will be a build for Revit 2019 soon.
Nik
I thought we fixed this bug quite a while ago. Are you using the latest version of the plugin?
Nikolaj Knudsen
Post by Nikolaj Knudsen » Tue May 15, 2018 9:33 pm
Hi Fused
Yes, latest plugin v2018 - 2017 is fine
Nikolaj Knudsen
Post by Nikolaj Knudsen » Fri Jun 08, 2018 11:04 pm
Nik
Any news on this problem? - really need to control the views and settings
Another question: are ies profiles exported from lights or materials in Revit and how?
Post by fused » Thu Jun 14, 2018 12:53 am
try this build: https://www.indigorenderer.com/forum/vi ... 38&t=14884
please let me know id this solves the problem for you.
Regarding IES profiles: IES profiles are read from revit light sources, depending on the "distribution" set in the asset:
- For "Spot" an IES file is generated from the spot parameters.
- For "Web" the referenced IES file is used.
- For all other IES is not set.
Nikolaj Knudsen
Post by Nikolaj Knudsen » Thu Jun 14, 2018 1:49 am
Hi Fused
Sorry, but it dosn't solve it. I can change the different settings but it jumps back again to default values.
Could it be some security settings is blocking the read/write access to something?
Regarding ies profiles -how do I control the strength then? Are the ies profile tied to a material?
Post by fused » Thu Jun 21, 2018 8:06 pm
Hi Fused
Nikolaj,
the only change in 2018 that I could think of being related to this issue is that the automatic transaction mode was removed and transactions always have to be handled manually now.
I have checked the transaction error handling code again, and if that were the cause, there there should be an error message.
I'm currently going over some other code improving error handling. If you could send me a pm with a contact where I can send builds for you to try, that would be greatly appreciated.
