Realtime preview doesn't work anymore
7 posts • Page 1 of 1
Post by zeitmeister » Fri Jun 02, 2017 12:12 am
Hey there,
I noticed that case from time to time. I've got a scene here which doesn't startup in the realtime preview window.
I added the scene into a new one, no chance. I emptied the quickrender folder, no luck.
Restarted the computer, the same.
What else can I do? Which prefs or folders do I have to clear or delete to get it working again?
C4d R14, Cindigo 4.0.48, Windows 7.
Thanks in advance!
Re: Realtime preview doesn't work anymore
Post by zeitmeister » Fri Jun 02, 2017 12:26 am
Edit: Same with latest Cindigo 4.0.51
Originalplan®
Post by Originalplan® » Fri Jun 02, 2017 2:34 am
Hmmm.... in Cinema IPR works well on Mac.
Cinema Update??
Post by zeitmeister » Fri Jun 02, 2017 4:08 am
No, it's always okay to a certain point. It works in new scenes. But at some point, it stops working in a certain scene. Now it doesn't export to Indigo GUI anymore.
I guess I have to import object by object into a new scene to figure out what's happened.
burnin
Post by burnin » Fri Jun 02, 2017 7:56 am
IIRC - It could be (& most likely is) a missing texture problem (path changed, either moved or removed) since Indigo doesn't communicate with Cinema's Texture Manager you will get no errors, but simply no action, no response. In such case, only manual check & fix works.
Post by zeitmeister » Fri Jun 02, 2017 5:33 pm
Supposed that... thank you! Didn't change anything there consciously...
Post by fused » Fri Jun 02, 2017 10:55 pm
Thanks burnin, will fix.
