Design of classic kitchen
8 posts • Page 1 of 1
pavoda
Post by pavoda » Tue Jan 10, 2017 4:43 am
Older project, now rendered by Indigo.
Re: Design of classic kitchen
Post by Oscar J » Tue Jan 10, 2017 5:00 am
Nice! I like the sunlight a lot. Well detailed, very clean. What render mode, render time etc? :)
The roof draws a lot of attention being the most saturated part of the image. I think some more post pro could take this even further.
Zalevskiy
Post by Zalevskiy » Tue Jan 10, 2017 5:23 am
Very good rendering 8)
What kind of lighting you have applied? HDR or very bright lights / area?
pavoda
Post by pavoda » Tue Jan 10, 2017 6:11 am
thank you for opinions :)
This scene was illuminated only by standard indigo sun light. Big window is behind camera and there is pretty much sun.
The sun is a much over saturated in drop place, but I can´t set the more diffused sun.
It seems, setting of the sun a little limited if GPU rendering used. (Use captured simluation no effect etc.)
Some parameters.
Rendered by indigo RT
Render mode is GPU path tracing (GTX 960)
render time 8 hours,
reach 4 000 SPP, speed 2750k samples/s.,
resolution 2800x1750,
Camera agfapan-apx-025D, D65,
No exit portals (GPU)
Post by Oscar J » Tue Jan 10, 2017 6:41 am
I would try disabling GPU mode when changing the sun settings, and then re-enable GPU. For some reason sun+sky settings aren't updated when you try to change them in realtime in GPU mode. Regarding the sharpness of your sun:
* It looks really good when it's oversaturated like that IMO. :)
* If you want softer lighting I would really recommend using HDR lighting instead. Check Peter Guthrie's and Vizpeople's stuff.
Interesting to see a interior GPU render, though judging from your render time it's not that optimised for interiors yet.
Pixelflix
Post by Pixelflix » Thu Jan 12, 2017 4:27 am
Great picture! I am a fan of your accurate use of materials. Keep it up! :D
Greetings,
Pixelflix
Post by lycium » Sun Feb 26, 2017 4:55 am
Lovely clean work, great job!
pavoda
Post by pavoda » Mon Feb 27, 2017 1:05 am
Thanks, it pleased me :)
