Hey there,
is there a way to access the polygon normal angle to the camera?
My aim is a material which blends steep-angled polygons invisible to the camera.
Thank you in advance!
ISL-question: color shader depending on normal angle to cam?
- zeitmeister
- Originalplan®
Re: ISL-question: color shader depending on normal angle to
I think you can set something like this up in Xpresso.
Combine the Indigo Cam tag and Indigo Comp tag with a Boole and a rangemapper.
Plus some custom inputs on cam.
Or set up something similar via Python in c4d.
Kinda the 2 most viable options i think.
- zeitmeister
Hehe, tried this one but without success...Oscar J wrote:http://www.indigorenderer.com/materials/materials/1104
Doesn't this one use "camera normals"?
But it's possible; I think about the invidible to camera option.
Only as a ramp...
- zeitmeister
Good hint! Gonna try something... thanks!Originalplan[REGISTERED SIGN] wrote:I think you can set something like this up in Xpresso.
But I would prefer a clean ISL solution of course.
if you snap the code into your own shader, you need to create two color parameters named C1 & C2 respectively.zeitmeister wrote:Hehe, tried this one but without success...Oscar J wrote:http://www.indigorenderer.com/materials/materials/1104
Only as a ramp...
