Indigo for Cinema 4D 4.0.43
Post by fused » Fri Aug 05, 2016 3:28 am
This release might contain some serious bugs and usability issues. If you notice something weird, please let me know.
Windows:
Indigo Renderer:
indigo-for-cinema-4d-4.0.43-installer.exe - Includes installers for R11.5 - R15
Indigo RT:
indigo-rt-for-cinema-4d-4.0.43-installer.exe - Includes installers for R11.5 - R15
The R15 build should work fine with R16 and later.
Mac:
Indigo Renderer
indigo-for-c4d-4.0.43-R11-mac.zip
indigo-for-c4d-4.0.43-R115-mac.zip
indigo-for-c4d-4.0.43-R12-mac.zip (R12 version works with R13)
indigo-for-c4d-4.0.43-R14-mac.zip (R14 version works with R15 and probably later versions)
Indigo RT
indigo-rt-for-c4d-4.0.43-R11-mac.zip
indigo-rt-for-c4d-4.0.43-R115-mac.zip
indigo-rt-for-c4d-4.0.43-R12-mac.zip (R12 version works with R13)
indigo-rt-for-c4d-4.0.43-R14-mac.zip (R14 version works with R15 probably later versions)
Changelog:
* Updated to indigo 4.0.43 sdk.
* Fixed material export command.
* Fixed bug where UVs would be wrong (slightly faster mesh export).
* Added global MeshCache (faster consecutive render startup times).
* Fixed a bug where instances with indigo subdiv weren't recognised as instances.
* Disabled image saving in all preview or internal render scenarios.
* Added interactive preview prototype (currently only supports updates to camera, background settings and materials, nothing that sits in the scene hierarchy).
Re: Indigo for Cinema 4D 4.0.43
Post by fused » Fri Aug 05, 2016 3:46 am
And next time I'll update the download links, too...
Should be fixed now.
Post by fused » Fri Aug 05, 2016 4:32 am
Mac builds.
contegufo
Post by contegufo » Fri Aug 05, 2016 5:02 am
Problem solved, resolved instance, also it seems faster in rendering. Thank you!
CD4 v.13
Originalplan®
Post by Originalplan® » Fri Aug 05, 2016 5:07 am
fused wrote:Mac builds.
:D Thank you!
I think it's a YES! Progressive window rocks!
Couple things:
- Sometime you have to click on the render image to show up.
- Sometime i need to change from GPU to CPU to get the image show up.
- ? A pre defined SSP Like system would come handy?? Like in Indigo now for mat prevs?? < not sure.
- Camera's focal lenght and sensor size dont' match up for now with PR render generated image.
IT'S A VERY GOOD START!!!! super excited! :mrgreen: :mrgreen: :mrgreen: Thanks for Sharing mr.fused!
Post by fused » Fri Aug 05, 2016 5:13 am
:D Thank you!
Couple things:
IT A VERY GOOD START!!!! super excited! :mrgreen: :mrgreen: :mrgreen: Thanks for Sharing mr.fused!
What C4D version are you using?
Originalplan®
Post by Originalplan® » Fri Aug 05, 2016 5:16 am
:D Thank you!
Couple things:
R17.048 (Build RB147424)
Post by pixie » Fri Aug 05, 2016 5:17 am
Houston, the Eagle has landed!
contegufo
Post by contegufo » Fri Aug 05, 2016 5:50 am
Realtime preview where it is?
It also works with the CPU?
I found!
Originalplan®
Post by Originalplan® » Fri Aug 05, 2016 6:04 am
contegufo wrote:Realtime preview where it is?
I found!
It works like also like a Render region???Wow.
Post by pixie » Fri Aug 05, 2016 6:09 am
This is top notch! I can tweak the camera settings on the fly also! Next stop, lights settings and objects moving, then the bulk of functionality is IMOdone! :)
Post by pixie » Fri Aug 05, 2016 6:11 am
I found!
that's been there since ages... ;) try rather:
plugins> indigo for cinema > realtime preview
Originalplan®
Post by Originalplan® » Fri Aug 05, 2016 6:13 am
I found!
Look for the APE logo. 8)
Post by fused » Fri Aug 05, 2016 8:14 am
Originalplan® wrote:It works like also like a Render region???Wow.
No, but I was thinking about doing that :)
Post by zeitmeister » Fri Aug 05, 2016 8:48 am
Oh fused, this is AWESOME[TRADE MARK SIGN]!
Cheers, zeiti
