error please help SceneLoaderExcep: TinyXmlWrapper:
10 posts • Page 1 of 1
hugonam
Post by hugonam » Sat Mar 03, 2007 11:25 pm
this is the error :
Fatal error
SceneLoaderExcep: TinyXmlWrapper: could not find element ´normal_smoothin´in element ´mesh´ around line 4.....
help
afecelis
Post by afecelis » Sun Mar 04, 2007 1:50 am
Are you trying to run indigo by "executing" your xml file?
You have to modify the inifile that comes with indigo and set its path to find the xml you exported from your 3d app. Something like this:
"scenefilepath" "testscenes\blender\tests\02_phong.xml"
Then you just double click indigo's executable and the inifile will enroute it to find your xml.
Now, if you're using 3dsmax and any of the exporters available, you have to set up where to find Indigo's executable since Indigo gets launched automatically after the exporting process. In U3dreal's exporter, you have to modify the file m2i.ini and add your path to Indigo. Like this:
[Dirs]
indigodir=C:\Indigo
In suvakas' latest exporter, you'll find a section in the exporter's UI to set the path to indigo 07.
Post by Kram1032 » Sun Mar 04, 2007 2:30 am
Hey!!!
I've posted something here some hours ago, but it's not here!!!
:evil:
antalopata
Post by antalopata » Thu May 03, 2007 5:22 am
I and have not understood and have not found anywhere as will cope with this problem.
Post by Kram1032 » Thu May 03, 2007 5:24 am
uhm... PLEASE tell us more....
that's not quite exact...
what's your problem?
antalopata
Post by antalopata » Thu May 03, 2007 5:36 am
After button pressing "render" such message SceneLoaderExcep takes off: TinyXmlWrapper: could not find element ´ normal_smoothin´in element ´ mesh ´ around line 4.....
Those recommendations which has given "afecelis" to me have not helped. And are not absolutely clear.
P.S.
I am sorry for the my English. :(
Post by suvakas » Thu May 03, 2007 6:46 am
What's your Indigo version and exporter?
It sounds like you are using either old exporter with newer Indigo or old Indigo with new exporter.
antalopata
Post by antalopata » Thu May 03, 2007 6:57 am
exporter is 0.616 / indigo is 0.7 or 0.8 . Other version exporter at me is not present
Post by suvakas » Thu May 03, 2007 7:49 am
The exporter 0.616 is for Indigo 06. It doesn't work with newer versions.
I recommend you to use Indigo 07 final and latest Maxigo.
You can get the Maxigo from this thread:
http://www2.indigorenderer.com/joomla/f ... php?t=1180
There is also a tutorial video to get you started. I recommend you to check it out.
antalopata
Post by antalopata » Thu May 03, 2007 11:30 pm
Thanks! Now works!
