Dragon glass!
6 posts • Page 1 of 1
contegufo
Dragon glass!
Post by contegufo » Mon May 09, 2016 6:24 am
Hi
The model is placed on a floor with curved background; diffuse material.
1) In the first image between the model and the background there is a light area facing the background that reflects light. The model is then illuminated by indirect light with a good yield rendering.
2) In the second image the light area is pointing towards the model which is then illuminated by direct light from behind, noting the shadows. Both images have the same rendering time (BD, 11h.) but as we see there is still noise to be removed.
You can do many variations as putting the model within a box that diffuses light, or use an environment map.
They welcome contributions.
contegufo
Re: Dragon glass!
Post by contegufo » Tue May 10, 2016 2:48 am
Hi
Better balancing the two lights on two different levels (light 1 temp. 6500k, gain 1.0 and light 2 temp. 4690k, gain 0.01) you get a good one.
contegufo
Re: Dragon glass!
Post by contegufo » Wed May 11, 2016 7:06 am
This time the lighting is generated by a toroid and the material and an FSSS.
In the other picture the same lighting and glass festival and gold!
Re: Dragon glass!
Post by Oscar J » Wed May 11, 2016 7:13 am
Cool tests :)
contegufo
Re: Dragon glass!
Post by contegufo » Wed May 11, 2016 7:20 am
Thank Oscar.
The torus as a light source, at least in these examples, did me great satisfaction.
contegufo
Re: Dragon glass!
Post by contegufo » Fri May 13, 2016 7:16 am
Ambra version.
