Image projector
Come here for help & support.
5 posts • Page 1 of 1
Evgeniy
Image projector
Post by Evgeniy » Fri Apr 15, 2016 12:00 am
Urgently need help to achieve this result
contegufo
Re: Image projector
Post by contegufo » Fri Apr 15, 2016 6:15 am
Hi
Excellent result, as you did?
Evgeniy
Re: Image projector
Post by Evgeniy » Fri Apr 15, 2016 6:47 am
you understood me wrong, this is photo and i want make this effect in Indigo
Re: Image projector
Post by Oscar J » Fri Apr 15, 2016 7:40 am
Tricky challenge - I would have tried using a small emitter, contained in a box which has a hole in it with that particular shape. For that cone you will need a fog volume - search for the fog material in the material database.
Re: Image projector
Post by CTZn » Mon Apr 18, 2016 1:17 am
Be wary that as in every renderer, volumetric effects are the more costly.
You may want to actually model the carved pyramid and use a transparency map, perhaps make it an emitter or compose it with a camera-diffracted, light emitting version. I'm making this out but that depends on how urgent the need is.
Oscar proposed the best solution though, as in simulation.
Users browsing this forum: No registered users and 85 guests
