SkIndigo 3.8.33.1
SkIndigo 3.8.33.1
Changelog:
Added support for 'Skatter' plugin.
Fixed issue causing exception when Indigo could not be located.
RBZ: (Works on all platforms)
http://downloads.indigorenderer.com/dis ... 8.33.1.rbz
RBZ install instructions: http://www.indigorenderer.com/documenta ... o-rbz-file
Windows Installer:
Note for Sketchup 2016 users: The SkIndigo extension may need to be enabled in the Preferences. Please refer to the installation instructions.
Let us know if you hit any bugs!
Windows Installer:
Re: SkIndigo 3.8.33.1
Great news!OnoSendai wrote: Added support for 'Skatter' plugin.
How can we use it?
STUDIO AARON
STUDIO AARON
Home Design, Rendering, Animation, and Virtual Reality
The question was about the usage with Indigo.
The question is good.
I bought it and I want to use it
what it says "on the tin", Indigo "render only" integration accomplished
Ehm...what?
Just do some scattering with Skatter. Make sure to select 'use full geometry' not 'use proxies' when using a preset. Then export as normal and you should see the instances.
So there's no proxy scattering available?
- zeitmeister
Indigo uses it's own instances... so theres no advantage here for RAM consumption... exept in SketchUp, I presume.
Cheers, zeiti
Cheers, zeiti
I'm studying a little and it works thanks a lot Ono!
Having a problem. The material editor isn't switching over to the material i selected with su's editor. Im using the mac version. Switched finally
