Indigo freezes while rendering
I am currently working on scene and Indigo freezes while rendering. Never had that before in Indigo. Here is the scene.
https://onedrive.live.com/redir?resid=D ... ile%2cpigs
Re: Indigo freezes while rendering
Indigo version?
Tested here and had no real problems.
Only your 766MB big IGS file with all that grass instances is hard to scroll through in the Indigo GUI.
DO you maybe have OpenGL preview enabled? If yes, then try to render with that window closed.
Works perfectly fine for me too. 16 GB of RAM here.
Okay closed OpenGL Preview window and now it works. Tkank you Zom-B. btw I am using v3.8.29 and got 16GB of Ram.
Glad I could helpvasco wrote:Okay closed OpenGL Preview window and now it works. Tkank you Zom-B. btw I am using v3.8.29 and got 16GB of Ram.
BTW: the Normal Maps on the Grass have gamma set to 2.2. To work as intended gamma for normal Maps need to be @ 1.0.
Also is blending 50/50 of Phong with diffuse transmitter quite much of the last one. Usually 20 to 30% of DT should be enough for a nice result...
Hello Zom-B, I found the option to set the normal gamma in Indigo GUI but unfortunately there is no option for this the blender exporter
, but thanks for the tips anyway.
Actually there is. Go to the texture for your normal map, there will be a gamma slider there.vasco wrote:Hello Zom-B, I found the option to set the normal gamma in Indigo GUI but unfortunately there is no option for this the blender exporter, but thanks for the tips anyway.
okay, found it. My fault.
Users browsing this forum: No registered users and 80 guests
