Indigo Exporter for 0.7t5 - beta release
Locked
Post by fused » Thu Mar 01, 2007 10:57 am
current version is 0.2.5b!
download exporter
you may notice that i kept really close to BlackLizards exporter. i like the way it works.
Post by fused » Thu Mar 01, 2007 11:18 am
fixed a little bug :P
Post by Zom-B » Thu Mar 01, 2007 12:10 pm
nicccccccceeeeee :D
I'll give it at try to check out the "look & feel" 8)
<joking>for a first release you perhaps should explain what does work,
the list would be shorter :P </joking>
Staying close to BL Exporter is a good Idea, so I don't have spend houers to learn everything about it ^^
Good work, and many thanx for this great job dude!
Post by Zom-B » Thu Mar 01, 2007 12:40 pm
Ok, I just tested it!
here are some bugs I found, just to fill your list on the first posting :D
- "Plugins > Indigo Exporter 0.7.5 > About" doesn't work for me
- "Internal Medium > Phase function" no settings for greenstein or uniform to set, it also gets exported strange!
- exporter just exports a justsomerandomcrap.xml, no matter what I call it ^^
- no 3ds export for me (c4d 9.62) also no hints for the meshes in the XML file
- NK materials dont work
- NK settings, transparency, color are availible to each of phong diffuse etc. materials, but get exported correctly :wink:
This first test release is very promissing!!!!!!!!!!1
Post by fused » Thu Mar 01, 2007 12:51 pm
i know most of the bugs.
- about works for me neither
- i was not sure if uniform scattering is supposed to have a value. greenstein is not supposed to work :)
- i thougt justsomerandomcrap.xml was a good name for any scene
- NK is not implemented yet
the thing with the 3ds export and the meshes in the xml is strange. can you post the code?
Post by Zom-B » Thu Mar 01, 2007 1:03 pm
OK, after adding a light to the scene 3Ds export is enabled!
But the XML only refers to the lightsource and the 3Ds file includes all Objects like in "dual 3ds object mode" in BLs exporter...
here a link for the scene.
Post by fused » Thu Mar 01, 2007 1:09 pm
yeah i know. its a bit tricky to get every single object exported.
thanks, i will have a look at it
Post by OnoSendai » Thu Mar 01, 2007 5:35 pm
Thanks Fused!
Xman
Post by Xman » Thu Mar 01, 2007 7:06 pm
thank very much :D
how to setup?
Post by fused » Thu Mar 01, 2007 9:14 pm
hi Xman.
the setup is like in BlackLizards exporter. if you still dont know how to do it, maybe someone can write a little tut. if not, if will do it for the final.
TIP: save your scene before exporting. exporter causes crashes (eg when you forget to apply the material to the object, or to the material helper tag)
mertay
Post by mertay » Thu Mar 01, 2007 10:07 pm
thank very much
mertay
Pinko5
Post by Pinko5 » Fri Mar 02, 2007 12:07 am
Tnx for exporter Fused
Wich version of Cinema4d needed for this exporter??
Pinko. :wink:
WLAD
Post by WLAD » Fri Mar 02, 2007 12:31 am
big thanks for your exporter,
but i found a little bug. the plugin exports the difus material with "<color>"
parameter but it should be "<colour>" with an "u" befor "r". perhabs you can
split the material tag in to 4 separate tags, one for eacht kind of materials.
edit: in the object tag is alsou a bug the normal_smoothing is allways on false.
cu
WLAD
Xman
Post by Xman » Fri Mar 02, 2007 2:12 am
Hi fused,
I think you have misunderstood me,
My meaning is Exporter copy to where?
( Exporter copy to D:\the Program Files\C4D10.0 ?)
thanks you
manitwo
Post by manitwo » Fri Mar 02, 2007 2:15 am
of course where you put your other plugins too:
D:\the Program Files\C4D10.0\plugins :wink:
Locked
