Transparency.
8 posts • Page 1 of 1
contegufo
Transparency.
Post by contegufo » Fri Sep 25, 2015 3:45 am
Hi
In SketchUp the transparency value can be adjusted with a slider. In CINEMA 4D I'm forced to make a material blend?
Would not it be easier to use a slider?
Re: Transparency.
Post by Zom-B » Fri Sep 25, 2015 6:59 am
Please post requests marked as such in th properer subforum!
[REQ] Transparency in C4D
Also you don't need to do a blend in C4D!
Simply activate the blend option and use the % slider.
C4D automatically blends that with Null Material...
thesquirell
Re: Transparency.
Post by thesquirell » Sat Sep 26, 2015 1:08 am
Leaving a blank spot for a material slot inside C4D usually exports that slot as a null material, but bare in mind that if you it leave it blank inside a coating material it will automatically create a standard, white, diffuse material. So, in a way, we already have a slider that you want.
Re: Transparency.
Post by neo0. » Thu Oct 01, 2015 3:01 pm
I totally agree with you man! I would love to have a slider in indigo!
Stinkie
Re: Transparency.
Post by Stinkie » Sat Oct 03, 2015 4:23 am
Did someone say 'slider'? 8)
bubs
Re: Transparency.
Post by bubs » Sat Oct 03, 2015 9:36 am
:lol:
dakiru
Re: Transparency.
Post by dakiru » Sat Oct 03, 2015 9:58 am
neo0. wrote:I totally agree with you man! I would love to have a slider in indigo!
Their explanation makes sense:
Use a slider when you want your users to be able to set defined, contiguous values (such as volume or brightness) or a range of discrete values (such as screen resolution settings).
A slider is a good choice when you know that users think of the value as a relative quantity, not a numeric value. For example, users think about setting their audio volume to low or medium—not about setting the value to 2 or 5.
MSDN
contegufo
Re: Transparency.
Post by contegufo » Sat Oct 03, 2015 10:56 am
Hi
A slider and a numeric input field dynamic so we can all agree.
