SkIndigo 3.8.25.2 (beta)
Post by OnoSendai » Wed Jan 14, 2015 12:56 am
Changelog:
Fixed texture colour changes not being exported.
Changed default material exponent to 100. (was 1000)
Added automatic path fix-up for linked IGMS.
Fix for some external objs not being assigned materials properly.
Fix for 'undefined method `downcase' for nil:NilClass' error when texture filename is empty.
Fix for material preview not working properly with backslash characters in name.
Added some file type filters for open file dialogs in SketchUp 2014+
Minimum required Indigo version is 3.8.11.
RBZ: (Works on all platforms)
http://downloads.indigorenderer.com/dis ... 8.25.2.rbz
RBZ Installation instructions: http://www.indigorenderer.com/documenta ... o-rbz-file
Windows Installer:
If anyone gets a 'reference to deleted Entity' error message, please stop, write down what steps you just took, and send me the .skp scene! (support@indigorenderer.com)
EDIT: updated build with 'Added automatic path fix-up for linked IGMS.'
EDIT: updated build with 'Fix for some external objs not being assigned materials properly.'
EDIT: updated build with 'Fix for 'undefined method `downcase' for nil:NilClass' error when texture filename is empty.'
EDIT: updated build with 'Fix for material preview not working properly with backslash characters in name.'
EDIT: updated build with 'Added some file type filters for open file dialogs in SketchUp 2014+'
Re: SkIndigo 3.8.25.2 (beta)
Post by Pibuz » Wed Jan 14, 2015 11:56 pm
Seems wonderful! Thanks!!!
Post by OnoSendai » Thu Jan 15, 2015 1:00 am
If anyone runs into any bugs/issues with this build let me know!
Enrico
Post by Enrico » Thu Jan 15, 2015 3:00 am
Perfect!!!
bubs
Post by bubs » Fri Jan 16, 2015 1:54 am
Ono I have a scene that keeps crashing after about 20mins... but with no error report. Can I dropbox you the .pigs to have a look?
Post by OnoSendai » Fri Jan 16, 2015 1:58 am
bubs wrote:Ono I have a scene that keeps crashing after about 20mins... but with no error report. Can I dropbox you the .pigs to have a look?
Yes please!
bubs
Post by bubs » Fri Jan 16, 2015 2:00 am
Cool, will do! Thanks in advance.
snorky
Post by snorky » Wed Jan 21, 2015 8:22 am
the same problem as previous version...
help :)
skp file + obj
https://drive.google.com/file/d/0B85NcO ... sp=sharing
snorky
Post by snorky » Sat Jan 24, 2015 7:04 pm
any news? :D
Enrico
Post by Enrico » Tue Jan 27, 2015 1:18 pm
Hi Ono! I have a problem with "foreground alpha" option...the render start without problems but after more seconds the object slowly disappears and the background invades the scene!
I attach an image...
After more seconds
At the start
Enrico
Post by Enrico » Tue Jan 27, 2015 3:04 pm
After some tests I realized that the problem occurs with the option "vignetting" disabled!!!
snorky
Post by snorky » Sun Mar 01, 2015 12:29 pm
OnoSendai wrote:EDIT: updated build with 'Fix for some external objs not being assigned materials properly.''
don't work...
scattered object's material set to default
EDIT....
sorry! ...works
I remove any default material on component (front face and back face too)
Did you want that it works in this way?
Post by Pibuz » Sun Mar 01, 2015 10:49 pm
Hi Snorky! ...What do you mean? You have to unassign the defailt sketchup material from the dummy component for the instance to work?
Ciao Max! Che vuoi dire? Bisogna rimuovere il materiale default di sketchUp dal componente dummy per far sì che l'instancing funzioni a dovere?
snorky
Post by snorky » Mon Mar 02, 2015 6:19 am
Pibuz wrote:Hi Snorky! ...What do you mean? You have to unassign the defailt sketchup material from the dummy component for the instance to work?
yes... works for me if dummy model has not a default material (front and rear face too)
(hahaha, Pibuz translate for me if my english is bad, thanks)
EDIT:
sorry, after more test, ...no default material only on front face.. (rear face color irrelevant)
EDIT: now works... :/
Post by Pibuz » Wed Mar 11, 2015 3:26 am
Ok, roughly testing.
Small issue: I have made a material and ran the preview. When I change the material's parameters and I run the preview again, the small icon gets updated but when I click to enlarge it I get the old preview. Deleting the old png from the roaming folder doesn't solve the issue..
EDIT: this does NOT seem to happen with all materials, just with one in particular, whose thumbnail is generated automatically as if Indigo is trying to save the preview again and again...
