Indigo Renderer 3.8.17 Beta Release
8 posts • Page 1 of 1
Post by OnoSendai » Mon Nov 17, 2014 7:15 am
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.8.17_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.8.17_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.8.17.tar.gz
IndigoRenderer3.8.17.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.8.17_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.8.17_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.8.17.tar.gz
IndigoRT3.8.17.dmg
Changelog:
3.8.17
* Optimisations for IES, motion blur, misc.
* Fixed problem with camera orientation jumping in some cases when camera settings were changed.
* Fixed network rendering problem where only a non-network accessible IP address for the master would get sent to the slaves.
* Added some code so you can't use transparent materials for double-sided thin front or back material.
* Fixes crash when using specular, glossy transparent etc.. for front or back mat.
* Added allow_gpu_as_slave setting to settings.xml.
* Fixed background map rotation not working in simple mode.
* Updated new (captured-simulation) sky model.
Re: Indigo Renderer 3.8.17 Beta Release
Post by zeitmeister » Mon Nov 17, 2014 7:29 am
Very cool, thank you!
Cheers, zeiti
Post by CTZn » Mon Nov 17, 2014 7:42 am
how fresh, thanks !
Patrice
Post by Patrice » Tue Nov 18, 2014 6:13 pm
Have this when opening my file :
Error while building scene: Error while loading double-sided thin material 'Indigo Material_blendA': Front material for a double-sided thin material can't be transmitting. Front material type: BlendMaterial.
Indigo version: Indigo RT v3.8.17, OS X 64-bit build.
Exporter: Indigo for Cinema 4D 3.8.6
Platform: Mac OSX 64-Bit
No problem with RT v3.8.16 or other version.
bubs
Post by bubs » Sat Nov 22, 2014 12:19 am
I'm having the same error with double sided thins which previously worked.
With me it's leaves on trees, so I assumed that the issue was in relation to clip maps applied to the leaves (ie a blend between the leaf and null). I removed all the clip maps and tired again... but I still get the same error, I've checked the materials coming up on the error and there is definitely no Blend materials any more... any suggestions?
Post by OnoSendai » Sat Nov 22, 2014 1:30 am
Can replicate the problem, will fix.
bubs
Post by bubs » Sat Nov 22, 2014 2:25 am
Thanks Ono
Patrice
Post by Patrice » Sat Nov 22, 2014 5:00 am
Thank you
