Camera Response Function fails
5 posts • Page 1 of 1
TheGreatGig
Post by TheGreatGig » Thu Oct 30, 2014 3:17 pm
Hi, I keep getting an error when trying to open scenes I've just exported from Maya. Error is as follows:
"Error: Failed to load camera response function from file "/Applications/Indigo Renderer/Indigo.app/Contents/MacOS/../Resources/data/camera_response_functions/.txt": Could not find file '/Applications/Indigo Renderer/Indigo.app/Contents/MacOS/../Resources/data/camera_response_functions/.txt'"
I'm running Indigo Renderer on Mac OS 10.10.
I saw something similar to this in the 3DSMax forum, but the solution was replacing their plugin with a new one someone provided, so that doesn't help. Hopefully someone knows what's going on. Let me know if you need any more info.
~gig
Re: Camera Response Function fails
Post by CTZn » Fri Oct 31, 2014 4:52 am
Hi, could you please specify the exporter involved ? There's a catch.
TheGreatGig
Post by TheGreatGig » Sat Nov 08, 2014 5:03 am
CTZn wrote:Hi, could you please specify the exporter involved ? There's a catch.
Hi, I'm using MtI 3.6.5.
TheGreatGig
Post by TheGreatGig » Mon Nov 10, 2014 4:35 pm
Post by CTZn » Wed Nov 26, 2014 5:14 am
Hi, sorry for the late answer TheGreatGig, I didn't acknowledge your answer till now.
The thing is, CTZn's MtI is not supported anymore, and in particular, I had never the chance to test it on a different OS than Windows. I am not sure about what is causing the error, sorry about that.
One dirty way to fix this would be to hand edit the IGS file as a text and correct the path stored in the tonemapping node.
