Indigo Renderer 3.8.14 Beta Release
15 posts • Page 1 of 1
Post by OnoSendai » Mon Sep 29, 2014 11:02 pm
This release fixes a lot of little issues, including a lot of GUI annoyances.
There are also lots of little optimisations.
It's entirely possible we have broken something, if you find something, or get a crash, please post about it in this thread or send us an email!
Indigo for Windows 32-bit:
IndigoRenderer_3.8.14_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.8.14_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.8.14.tar.gz
IndigoRenderer3.8.14.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.8.14_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.8.14_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.8.14.tar.gz
IndigoRT3.8.14.dmg
Changelog:
3.8.14
* Small bidir optimisation.
* Texturing, bump mapping optimisations.
* Added an optimisation, which is to use greyscale versions of textures for bump, displacement params etc.. Thanks to Zom-b for suggestion.
* Adjusting the min and the max on the linear tonemapping slider, so that the slider is still useful if the scale value is very small or large.
* Disabling albedo channel and IOR spinbox when specular reflectivity is enabled.
* Disabling IOR spin box, spec reflectivity and albedo channels when nk data is enabled in Phong control.
* Setting GUI progress bar state to total fraction through render if there is a halt time or halt spp.
* Mentioning halt time or halt spp in the status text.
* Made space bar start/pause/resume rendering.
* Blend materials now return the child material id colours blended.
* Depth tracer and material id tracer now go through nulls.
* Only saving alpha channel with EXRs when an alpha channel is used in the rendering.
* Fixed returning from full-screen mode losing focus.
* Fixed insufficient range on Atmosphere medium position Vec3 control.
* Made exit portal a proper material type in the Material control UI.
* Recording state (collapsed or not) of collapsable group boxes between Indigo launches.
Re: Indigo Renderer 3.8.14 Beta Release
Post by Oscar J » Tue Sep 30, 2014 1:32 am
Whoa, nice release!
bubs
Post by bubs » Tue Sep 30, 2014 2:31 am
Thanks Ono! great release!
Post by CTZn » Wed Oct 01, 2014 5:37 am
The preview material scene does not allow volumetric shaders to render. Constant values work fine...
Post by Pibuz » Fri Oct 03, 2014 9:56 pm
Hi Ono, don't know if it's only my problem, but I can't edit the camera parameters in the Indigo GUI anymore. I was trying to change the focus point while the render was going..
EDIT: also, I have some problems exporting a previously exported scatter test scene... Gonna test further..
Post by OnoSendai » Fri Oct 03, 2014 10:15 pm
Pibuz wrote:Hi Ono, don't know if it's only my problem, but I can't edit the camera parameters in the Indigo GUI anymore. I was trying to change the focus point while the render was going..
The focus distance spinbox is disabled if autofocus is enabled, if that's what you mean. Just disable autofocus.
Post by Pibuz » Fri Oct 03, 2014 10:40 pm
..the problem is that I can't actually see anything in the property editor window if I select metadata, render settings, or tonemapping. Mesh, material and object work fine instead.
Post by OnoSendai » Fri Oct 03, 2014 10:42 pm
Pibuz wrote:..the problem is that I can't actually see anything in the property editor window if I select metadata, render settings, or tonemapping. Mesh, material and object work fine instead.
That's because we haven't implemented the UI for those node types yet :)
Post by Pibuz » Sat Oct 04, 2014 1:20 am
Oh ok, so that is fine :) Thanks.
I attach a tiny scene which gives me some problems, maybe a mapping export problem..
2Dgrass_error.zip
(1.76 MiB) Downloaded 580 times
Post by pixie » Sat Oct 04, 2014 1:47 am
This scene crashed me in bidir mtl
http://ge.tt/5ncGUY02/v/0
Post by OnoSendai » Sat Oct 04, 2014 1:59 am
pixie wrote:This scene crashed me in bidir mtl
Did Indigo pop up a dialog when you restart it saying to send a crash dump?
Post by OnoSendai » Sat Oct 04, 2014 2:36 am
Thanks for bug report, have fixed problem for next release (crash with MLT mode)
bubs
Post by bubs » Sun Oct 05, 2014 2:26 am
Does Mat ID tracer not work for non perspective modes? or am I doing something silly?
Post by OnoSendai » Mon Oct 06, 2014 11:07 pm
bubs wrote:Does Mat ID tracer not work for non perspective modes? or am I doing something silly?
You appear to be correct :)
Will fix :)
Post by pixie » Thu Oct 09, 2014 9:36 pm
OnoSendai wrote:Small bidir optimisation.
Path bidir is so good nowadays that it trashes all the other modes in almost every situation, interiors, you name it...
