SkIndigo 3.8.11.1
13 posts • Page 1 of 1
SkIndigo 3.8.11.1
Post by OnoSendai » Sat Sep 06, 2014 12:46 am
Changelog:
Version 3.8.11.1
Added back in 'Thin Glass' material type. Now exports as arch-glass, with single-face mode enabled.
Added more progress feedback for mesh building.
Printing num materials exported.
Fixing up SketchPhysics export.
Minimum required Indigo version is 3.8.11.
RBZ: (Works on all platforms)
http://downloads.indigorenderer.com/dis ... 8.11.1.rbz
Windows Installer:
Re: SkIndigo 3.8.11.1
Post by Pibuz » Sat Sep 06, 2014 10:56 pm
Wonderful thanks!
So we now have:
1."thin glass" shader which gets exported as "single face arch glass" and
2."arch glass" option on specular shader which gets exported as "arch glass" for volumes
Post by OnoSendai » Tue Sep 09, 2014 12:06 am
Pibuz wrote:Wonderful thanks!
So we now have:
Yes, that's correct.
Post by Oscar J » Tue Sep 09, 2014 2:29 am
Maybe you could explain in the GUI (no thickness required) or something.
Post by OnoSendai » Tue Sep 09, 2014 10:43 pm
Updated builds in place, fixed some issues with animation and background export.
ak-sam
Post by ak-sam » Thu Sep 11, 2014 9:10 am
Awesome - thank you !!! :mrgreen:
Post by Pibuz » Fri Sep 12, 2014 8:32 pm
.. :( PLEASE.. I know it sounds silly but...PLEASE revert default material to diffuse!
..or at least think of a way to change the shader type assigned to SU default material inside SkIndigo!
Post by OnoSendai » Thu Sep 18, 2014 5:18 am
Updated build to fix problem when mesh uses multiple UV sets. (multiple UV sets are disabled for now.)
Pibuz wrote:.. :( PLEASE.. I know it sounds silly but...PLEASE revert default material to diffuse!
Why do you want diffuse to be the default?
snorky
Post by snorky » Thu Sep 18, 2014 7:34 am
for me, diffuse is 5-8% faster than oren...
Post by Pibuz » Mon Sep 22, 2014 11:30 pm
Hi Ono!
..that's mostly because most of the time I usually use sketchup default material to represent the standard white wall plaster, so in my projects there are actually a lot of walls painted with that, that is NOT painted at all. Moreover, as far as I know, there is no way to adjust the Indigo material setting for sketchup's default material through skindigo, so to get a fast preview render I should fiddle directly in the Indigo GUI to covert that to diffuse. I know that really subtle reflections give a far much realistic look, but most of the times I prefer to spare some rendering time in spite of that. Only in very few occasions I tried to give a phong material to the white walls, and that is when I find useful to make a specific material and paint it where I need.
There is another reason: I teach Indigo and SkIndigo, and most of the times my students ask me why is that phong and not diffuse? :lol: Another thing that I used to teach is that - when working with Sketchup AND SkIndigo - to create a new SketchUp mat it is useful to start with the default sketchup material, so we have a new SkIndigo material with very basic settings, sort of a standard mat so-to-speak, a generic material setting just to start. Now it's not: even if I start with the simplest SketchUp mat, I have to open skindigo material editor and convert it to diffuse manually.
I always teach thinking: let's start from easy and then get to complex. The current preset forces the workflow back and forth, and for a beginner that is not good, according to me.
lape
Post by lape » Sat Sep 27, 2014 10:55 pm
+1 !!!!!!!!!!!!
24 hours isn't enough
http://www.werkraum3d.com
ak-sam
Post by ak-sam » Wed Oct 01, 2014 9:21 am
If we could adjust defaults, that would be great!
